Sup guys, i just had to send back my hifonics brx 1100d brutus cause basically it's a pos and shit the bed on me in 2 months at 2 ohms..anyways any suggestions for an amp that can give me 1200 rms at 1 ohm that's a reputable amp, or one that does 1200 @ 2 ohm and why that would be a better choice?
Should be plenty of choices out there. Have you considered the Sundown 1200?
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
What is the impedance of your subs. The reason I'm asking is you can not run at 2ohms and 1ohm from the same set of subs. For example if you have a duel 2 sub it can be run at 1ohm or 4ohms not 2ohms same with a duel 1 2ohms or .5ohms.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
at 1000 rms id probably look at the sq1200, because its cheap...or find an arc ks1000/ks1200 on the cheap. you've already stated that sundown is to much money for what you want to spend, so i'd look at used options of sundown and other dependable amps, rather then buy some budget friendly POS.
I love my prime 1200d it's pushing a sq hdc3 12. Also the sq 1200d would be nice to
Edit: what is the impedance of the sub or subs your running just to make sure of the correct ohm load
141 on music.
I must ask do you have any idea why your Brutus blew up on you? That would be one thing I would try to figure out because the Brutus amps are suposto be good amps for the money.
141 on music.
I have been using it on lower volume, not blasting it too much for only 2 months. It was wired at 2 ohms and i have the wires and power to support it, and what happened was i was driving and had it on very low volume " 15/35 " and after a few songs the sub just turned off, no protect mode, nothing. I tried everything and the only thing i could notice was the speaker terminal spot wasn't being illuminated anymore, as it was before when it worked. Not sure if that has anything to do with it though
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
