Finally got around to wiring up my gauge pod.
What better than a factory ground?
New 3rd brake light to get rid of the rear deck light so I can do fiberglass
Also works as a reverse light and there is a wire for running light (which won't be used)
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
Yes it is, not sure what zip it is though, my itunes didn't recognize the zip designation as i downloaded them.
Finished up the ashtray switch after dinner, as well as the floor deadening. I have about 26 sq ft left over for the doors, roof and trunk.
Tight squeeze even after i shortened the wire ends (Thankfully they were able to come apart and cut them down a bit)
Cleaned up wires
Now you see them
Now you don't
Unfortunately the switch panel stays on regardless of where the switches are. Luckily enough i have one more wire set in the plugs i'm using for the gauge switches so i will use it to cut the switch panel power when it's not in use. Sounds a bit confusing but as long as i get time tomorrow to work on it, i'll have pictures to show lol.
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
I love how you did the switches. Gauge pod looks good too. Personally, I would had used digital but that's because i like the pretty colors haha. Still awesome though, keep up the good work.
I would have went digital but the refresh rate is quicker on the analog gauges I have. I want to know exactly what it is when it happens. I have the voltage gauge on my CD player and it can't keep up with the analog gauges in showing exactly. The only digital gauge i would consider is the VM-1 and thats ONLY if it were able to fit in the pillar pod.
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
So under dash lights and gauges wired and operational
To help combat the voltage drop at the amp, i decided to take one of the D3100s out of my truck off the charger and put it in place of the D3400 that is back there now.
Shall see what happens this evening, maybe get a video.
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
Voltage still drops like a rock but it bounces back quicker on the 3100. May put a second one in just because i can lol. Im pretty sure 2 will fit lol
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
