getgcs Posted August 22, 2013 Author Report Posted August 22, 2013 can u be more specific about the system you have.. what amps, speakers .. pictures of wiring and distribution blocks would help.. 5 amps and I assume no extra batts is not a good idea.. Sure It is quite complex so Ill try soon.. in the mean time I have one yellow top optima batt thats 6 months old and a 5 farad cap. then I have about 4000rms total power but again how do I troubleshoot this NEW problem. for 6 months I havent had this wine noise and it just started a day or two ago.
shackleford Posted August 22, 2013 Report Posted August 22, 2013 this is an issue of ground potential. reground the amps and ground out the rca shields to the case of the deck.
shackleford Posted August 22, 2013 Report Posted August 22, 2013 and the pico fuse blows if youve ever connected/disconnected any rcas with the deck and system on. signal or no signal it sends a spike down the line and boom. like the popping sound it makes if you have your deck on aux already and go to plug a phone/ipod in
getgcs Posted August 22, 2013 Author Report Posted August 22, 2013 this is an issue of ground potential. reground the amps and ground out the rca shields to the case of the deck. "rca shields to the case of the deck" What are the rca shields and where is the ground on the case of the deck? A pic on this would be awesome but not needed.
getgcs Posted August 22, 2013 Author Report Posted August 22, 2013 and the pico fuse blows if youve ever connected/disconnected any rcas with the deck and system on. signal or no signal it sends a spike down the line and boom. like the popping sound it makes if you have your deck on aux already and go to plug a phone/ipod in Where is the fuse? is it the only one on the back or can there be more than more than one on the back of the deck?
getgcs Posted August 22, 2013 Author Report Posted August 22, 2013 Ok I was wrong this is very important too: The high pitch wine noise doesn't happen when I put the system on in accessory mode. It only happens when the car and system are both on. It also gets louder when I drive the car.
Soccerballzs Posted August 22, 2013 Report Posted August 22, 2013 Hey you could have a bad RCA. Could be bad ground. On your jeep is there a cooling fan or electric motor? If there is a stud in front of alternator if so run 0 wire to battery from engine. No need to ground alternator if you do this. Check RCA'S http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
rockFord_Expedition Posted August 22, 2013 Report Posted August 22, 2013 Ok I was wrong this is very important too: The high pitch wine noise doesn't happen when I put the system on in accessory mode. It only happens when the car and system are both on. It also gets louder when I drive the car. Ok I was wrong this is very important too: The high pitch wine noise doesn't happen when I put the system on in accessory mode. It only happens when the car and system are both on. It also gets louder when I drive the car. That's how engine noise works but. If I was you I would google how to ground our rca's to he deck, do that and see what happens. I would also ground your alternator case to the frame just because it is good to do. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
getgcs Posted August 22, 2013 Author Report Posted August 22, 2013 I did ground the alt to the frame and I do have a power bolt on the alt thats going to the battery if thats what you mean. Now since the RCA's in the back of the desk (that never move) were working fine for 6 months do you think it could be something else?
