Ohm load help!
Just breezed through your build log. Even then you said one sub was moving noticeably more than the others. It was probably wired lower. Better safe then sorry, I'd pull the subs.
Just picked a cheap one up real quick from an O'Reilly because I realized I always used my friends. I'm guessing its not too good haha. Touched the leads together and got 0.00
Yea that did happen at first but once I got them gain matched by chevy4x4blazer when he used the dd1 to tune them. Also when I had them playing with the bc5500 before the water killed it they looked fine.
I'll pull them if I have to but they are terrible to pull haha 62lbs each trying to remove them while sitting down inside the car
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
To achieve a 1 ohm load with 4 voice coils, do this: http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~2~I~12 forget that the diagram shows 2 subs, just focus on the fact that there are 4 1 ohm voice coils wired to 1 ohm. You have two subs per amp, so you are running your amp at .5 ohm. Is that what you are aiming for?
I am aiming to run at 1ohm. Not to be rude but I knew everything you just said, I've been trying to figure out how to run all 4 at 1 ohm off the bc5500. The ap3ks were running at 1ohm
Edit. Ignore this. I went dumb for a bit
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
crap I'm sorry man. I looked at that completely different and then responded. I understand what you are saying now.
So, look at my 4 sets of 1ohm terminals as a voice coils? Very nice, that helps a lot
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
You said you are a visual person, I forgot that part..
First, on a mono block amp, 2 subs with quad 1 ohm coils, a 1 ohm load is not achievable. The closest you will get is .5, or 2 ohms. Picture this diagram as two of your subs. I know the diagram says four subs, but the only thing that really matters is that you have 8 voice coils on a mono block amp. So just to clarify, each pair of subs in the diagram is equivalent to one of yours.
you could also do .125 or 8 ohms but neither of those are practical.
So now, is your amp stable down to .5? I don't know how much box rise you have etc. you are getting and keeping in mind that impedance is nominal, especially on music, this could be doable. You better have a STOUT electrical system to say the least, plus a whole lot of other things done right to run safely that low.
2 ohms would be a lot safer though.
You know I have 4 subs right?
I do not want to risk anything with this amp at .5
I appreciate all your quick responses and trying to help me through this!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Is your amps on? When you tested?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Amps were on yes. I probably did it wrong. Checked with them off and got no reading
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   0 Members, 0 Anonymous, 1375 Guests (See full list)
