Daddy_ Posted August 24, 2013 Report Posted August 24, 2013 Hey guys I've been getting some mixed information about my electrical whether I can run what I have chosen for my audio system. Some people have said it is fine and some people have said you need to upgrade to better equipment or run more batteries. Let me give you some background information on what car it is and what equipment I'll be running. 2013 Honda Accord Coupe V6 HFP. The total RMS of this system is 3100. Front Speakers: JL Audio C5 3-way 6.5" Rear Speakers: JL Aduio C5 2-way 6.5" Speaker Amp: JL Audio 600/4 Subs: 2 12" Sundown X (Might change my mind but there all in the 1000-1250RMS range) Sub Amp: Sundown SAZ-2500D V.2 or RF T2500BDCP Now here is the electrical I plan on putting in. Let me know if there is a problem or anything else I can do to make it better. Alternator: Mechman S Series 240A Front Battery: XS Power D4800 (I could run the D2400 or D2700 but will require modifying the factory pos and neg terminals) Rear Battery XS Power XP3000 Big 3 done in all 0 guage Also a question can I have both batteries hooked up to my alternator so they can both charge or can I only have the front one. If I cant have both hooked up my only option is to get a battery charger? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
ChevyBoy95 Posted August 24, 2013 Report Posted August 24, 2013 Hey guys I've been getting some mixed information about my electrical whether I can run what I have chosen for my audio system. Some people have said it is fine and some people have said you need to upgrade to better equipment or run more batteries. Let me give you some background information on what car it is and what equipment I'll be running. 2013 Honda Accord Coupe V6 HFP. The total RMS of this system is 3100. Front Speakers: JL Audio C5 3-way 6.5" Rear Speakers: JL Aduio C5 2-way 6.5" Speaker Amp: JL Audio 600/4 Subs: 2 12" Sundown X (Might change my mind but there all in the 1000-1250RMS range) Sub Amp: Sundown SAZ-2500D V.2 or RF T2500BDCP Now here is the electrical I plan on putting in. Let me know if there is a problem or anything else I can do to make it better. Alternator: Mechman S Series 240A Front Battery: XS Power D4800 (I could run the D2400 or D2700 but will require modifying the factory pos and neg terminals) Rear Battery XS Power XP3000 Big 3 done in all 0 guage Also a question can I have both batteries hooked up to my alternator so they can both charge or can I only have the front one. If I cant have both hooked up my only option is to get a battery charger? when running multiple batteries all you have to do is run a power wire from either the front battery or a secondary alt charging lead to the rear battery, and ground the rear battery to the frame.... DONE. you dont need a battery charger or anything like that, the alt will charge both. I would suggest, and obviously, D4800 up front... 1/0 OFC charging lead from the alternator to the front battery, then 2 runs of positive 1/0 to the rear battery, 1/0 OFC from the rear battery to the amp. Same with grounds but alt ground to frame (or front battery), front battery grounded to frame, rear battery grounded to frame. and make sure when grounding, to either match the amount of wire that the positive side has (2 positive 1/0 runs, so you WILL need 2 1/0 negative runs) or run more that the postive side (2 positive 1/0 runs, 2 or more 1/0 negative runs). edit: on an aftermarket alt MADE to power huge banks or large electronic draw, you can put 6 batteries on that one alt if need be, hell as many as you can fit. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Daddy_ Posted August 24, 2013 Author Report Posted August 24, 2013 Hey guys I've been getting some mixed information about my electrical whether I can run what I have chosen for my audio system. Some people have said it is fine and some people have said you need to upgrade to better equipment or run more batteries. Let me give you some background information on what car it is and what equipment I'll be running. 2013 Honda Accord Coupe V6 HFP. The total RMS of this system is 3100. Front Speakers: JL Audio C5 3-way 6.5" Rear Speakers: JL Aduio C5 2-way 6.5" Speaker Amp: JL Audio 600/4 Subs: 2 12" Sundown X (Might change my mind but there all in the 1000-1250RMS range) Sub Amp: Sundown SAZ-2500D V.2 or RF T2500BDCP Now here is the electrical I plan on putting in. Let me know if there is a problem or anything else I can do to make it better. Alternator: Mechman S Series 240A Front Battery: XS Power D4800 (I could run the D2400 or D2700 but will require modifying the factory pos and neg terminals) Rear Battery XS Power XP3000 Big 3 done in all 0 guage Also a question can I have both batteries hooked up to my alternator so they can both charge or can I only have the front one. If I cant have both hooked up my only option is to get a battery charger? when running multiple batteries all you have to do is run a power wire from either the front battery or a secondary alt charging lead to the rear battery, and ground the rear battery to the frame.... DONE. you dont need a battery charger or anything like that, the alt will charge both. I would suggest, and obviously, D4800 up front... 1/0 OFC charging lead from the alternator to the front battery, then 2 runs of positive 1/0 to the rear battery, 1/0 OFC from the rear battery to the amp. Same with grounds but alt ground to frame (or front battery), front battery grounded to frame, rear battery grounded to frame. and make sure when grounding, to either match the amount of wire that the positive side has (2 positive 1/0 runs, so you WILL need 2 1/0 negative runs) or run more that the postive side (2 positive 1/0 runs, 2 or more 1/0 negative runs). edit: on an aftermarket alt MADE to power huge banks or large electronic draw, you can put 6 batteries on that one alt if need be, hell as many as you can fit. But will this electrical be enough to power what I am wanting? That is my main concern don't want to have the voltage drop low and blow my equipment. Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
ChevyBoy95 Posted August 24, 2013 Report Posted August 24, 2013 Hey guys I've been getting some mixed information about my electrical whether I can run what I have chosen for my audio system. Some people have said it is fine and some people have said you need to upgrade to better equipment or run more batteries. Let me give you some background information on what car it is and what equipment I'll be running. 2013 Honda Accord Coupe V6 HFP. The total RMS of this system is 3100. Front Speakers: JL Audio C5 3-way 6.5" Rear Speakers: JL Aduio C5 2-way 6.5" Speaker Amp: JL Audio 600/4 Subs: 2 12" Sundown X (Might change my mind but there all in the 1000-1250RMS range) Sub Amp: Sundown SAZ-2500D V.2 or RF T2500BDCP Now here is the electrical I plan on putting in. Let me know if there is a problem or anything else I can do to make it better. Alternator: Mechman S Series 240A Front Battery: XS Power D4800 (I could run the D2400 or D2700 but will require modifying the factory pos and neg terminals) Rear Battery XS Power XP3000 Big 3 done in all 0 guage Also a question can I have both batteries hooked up to my alternator so they can both charge or can I only have the front one. If I cant have both hooked up my only option is to get a battery charger? when running multiple batteries all you have to do is run a power wire from either the front battery or a secondary alt charging lead to the rear battery, and ground the rear battery to the frame.... DONE. you dont need a battery charger or anything like that, the alt will charge both. I would suggest, and obviously, D4800 up front... 1/0 OFC charging lead from the alternator to the front battery, then 2 runs of positive 1/0 to the rear battery, 1/0 OFC from the rear battery to the amp. Same with grounds but alt ground to frame (or front battery), front battery grounded to frame, rear battery grounded to frame. and make sure when grounding, to either match the amount of wire that the positive side has (2 positive 1/0 runs, so you WILL need 2 1/0 negative runs) or run more that the postive side (2 positive 1/0 runs, 2 or more 1/0 negative runs). edit: on an aftermarket alt MADE to power huge banks or large electronic draw, you can put 6 batteries on that one alt if need be, hell as many as you can fit. But will this electrical be enough to power what I am wanting? That is my main concern don't want to have the voltage drop low and blow my equipment. what you asked in the first question was more of HOW to wire a second battery, seemed like you had no clue. will be enough, yeah, but you will have a good amount of voltage drop most likely, a second D3100 would be ideal IMO. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Daddy_ Posted August 24, 2013 Author Report Posted August 24, 2013 By second battery do you mean replace the XP3000 with a D3100 ? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
Daddy_ Posted August 24, 2013 Author Report Posted August 24, 2013 bump. Still waiting on a answer on whether to run the D3100 over the XP3000. So I will be fine with 2 batteries and what king of voltage numbers will I see? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
soundstream15 Posted August 24, 2013 Report Posted August 24, 2013 Run 2 D 3100s and you will be set. 2 in the rear. I have a yellow top optima under my hood and kitneik hc2400 in the back, big 3 in 1/0 charging lead is welding wire but oh we'll I installed a mechman 170amp alt today and my volts drop to 12.6 and I'm running 3.5k. So 2 batteries in the back is a good idea
Daddy_ Posted August 25, 2013 Author Report Posted August 25, 2013 Run 2 D 3100s and you will be set. 2 in the rear. I have a yellow top optima under my hood and kitneik hc2400 in the back, big 3 in 1/0 charging lead is welding wire but oh we'll I installed a mechman 170amp alt today and my volts drop to 12.6 and I'm running 3.5k. So 2 batteries in the back is a good idea. So your running 3 batteries total? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
Daddy_ Posted August 25, 2013 Author Report Posted August 25, 2013 Noo, 2 total, should be 3 tho And how much is your total rms in your system? Include your woofers and your component speakers Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
