Thoughts on this 3 HDC3 15's box?
ChevyBoy95
What are your thoughts? current one is 10.5-11 cubic feet, tuned to about 34 with 2 8in aeros. Even with probably 5-6krms, i cant get them to max excursion (full potential in my mind).
Hopefully want to play 28-50hz well.
You won't get max excursion from subs in a shared environment. If you want maximum excursion, build two different chambers.
Wave breaks perhaps?
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
care to explain? and how will i have 2 chambers using 3 subs?
So, my info was wrong. I re-read the document that I was getting my info from(loudspeaker cookbook) and JUST realized that it's half the excursion for a 2 woofer CLOSED box setup. Sorry for that.
So, in brief, my answer sucked.
Lets see if I CAN help. I'm curious, you have 3 common walls entered, but the height doesn't seem to match up the to total box height. Almost 200" of port looks good to me, and the extra couple of cubes should help with efficiency.
port is drivers side up, subs up on the rest of the top.
Box should work out a lot better than the current box, definitely a lot more port, which will help because the subs have a lot of xmax, and vent mach is with in good range, so control will be there too, so you should have no issue playing 28-50hz, and break your 150.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Hence the 20.5" and the 22" that makes sense. I agree, it should be a damn good box. This is in an extended cab right?
yes.
  • Who's Online   0 Members, 0 Anonymous, 1191 Guests (See full list)
