dgreenie24 Posted August 28, 2013 Report Posted August 28, 2013 Hello - I am looking for a little assisance and opinions on the setup I'm currently looking to put together. It has been quite awhile since I have messed with anything car stereo related. I always had more fun installing everything than I did actually enjoying it, so I figured I would do something small and simple.. I just bought a 2011 Hyundai Sonata Limited (Turbo) with Nav & the Dimentions (Infinity) stock sound system. I would like to leave the factory Nav unit in place and use some sort of Line Converter. It has a stock 8" subwoofer (Free Air / IB) in the rear deck that I would like to replace with a Sundown SA-8. I am willing to build a box if I need to but I would prefer not to. Also this has the stock amp installed as well that I would use to power the interiors for the meantime. I was looking at the SoundQubed Q1-750 amp, would this be a good fit for (1) Sundown SA-8? Please let me know your thoughts and opinions. Which Sundown SA-8? Dual 2 ohm or Dual 4ohm? Will the SoundQubed Q1-750 power this subwoofer well? Or should I upgrade to the 1200D? Which Line out converter should I get? Not looking to spend a ton of money, maybe $400. I'm not looking for anything to shake the china off of my neighbors cabinet, just some nice solid clean bass with a little extra if I need it.
john253a Posted August 29, 2013 Report Posted August 29, 2013 Stick with the 750 but look I to the x8 there on pre-order at the moment Have you thought about building a box either sealed or ported Is so maybe look I to the 10" or 12"
Rmichael91 Posted August 29, 2013 Report Posted August 29, 2013 You could so an SMD BLD. Or Rockford. Just throwing 2 top line out there. Other option would be an audio control lci6, between the sa 8 and x 8 I'd take the x8 on preorder. Beefier design by far. Amp wise I'm the type of person to prefer headroom on power so Id take the 1200.
