DDX-319 Head Unit Subwoofer Preouts Not Working
The other day, my subwoofer suddenly cut out and I traced the issue to my subwoofer pre-outs on my Kenwood DDX-319 head unit.
Troubleshooting done so far:
No AC voltage comes out of the subwoofer pre-outs on the head unit at all
Connecting the sub amp's RCAs to the rear pre-out produces sound from the sub (ruling out that it is my amp or subwoofer)
There is no resistance (0 ohms) between my pre-out grounds and the case of the head unit (leading me to believe it is not simply a blown fuse in the head unit)
Everything else on the head unit functions as intended
My head unit is out of warranty by a couple months. I emailed Kenwood about the problem, but they will most likely give me the run-around and ask a million questions before giving me a repair quote that I expect to be at least $100, something I can't really afford right now with a new semester starting. I have some proficiency in electronics (enough to most likely be able to replace a broken component, if I can tell that it's broken), so I'll probably end up opening the head unit and seeing what I can do. I have never used the amp in the head unit, so it's unlikely that it's a heat-induced malfunction, in my eyes.
Any help I can get is appreciated, especially things that would help me repair the head unit, like what components could possibly be broken.
Thanks!
Are they turned on?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I guess that's the obvious question, but yes, they are turned on. The pre-outs stopped working randomly while I was driving, listening to music. I've reset the head unit to factory settings a few times, which didn't help.
Double check that they are on. It sounds like the headunit thinks they are off. Try flipping the settings a few times. You didnt touch anything on the deck right? Ive owned a few kenwoods that gettinf the subs on was a pain.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You said you reset the settings on the head unit, have you disconnected your battery to completely reset the HU? I know my X994 was acting up with my USB drive once, it wouldn't read it. So I disconnected the battery and it went back to normal.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
  • Who's Online   0 Members, 0 Anonymous, 1070 Guests (See full list)
