Hey guys.... i just got my 2 12 l7's installed with a crunch pzi. 3000.1. The system beats....but im gettin a lot of rattle from both the panels of the car and my windows (mostly the windows). I know a lot of people that use dynamat and stuff (which I might), but what can i do for the windows? i appreciate the help
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
ive been told another option is to take your door apart and tighten down the motors and everything in side. i have that same issue. actually mine sounds like someone is usin my windows as drums lol.
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
and that's when you go to a professional to do that.
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
Windows down lol. Dynamating everything too to stop car flex. But opening the windows deffinitally helps. And in some cases can make you louder. But will relieve pressure.
Louder from the outside or inside? I am assuming from the outside if it is relieving pressure. I think the windows he is talking about don't go down...he's talking about the back side panels of his expedition. I have seen his car many times.
2008 Chevy Impala (undercover cop style)
Setup in the makings
Louder outside and in.
Can you explain why it would be louder overall if you are putting sound and vibration deadening (sp?) material in there
Louder by opening the window is what I was writing to.
Well i also had that problem but instead i used dynamat now i dont have the rattle anymore.I always drive with my front windows all the way down and both windows at the back slightly open apparently kicks out more bass and ur car will definately sound louder from the outside. i`ve got 2 Fi Btl 12" running on a 5000w targa 2ohm amp and i can tell u wen i go to work peoples windows rattle wen i drive past their homes.Btw i`ve got a hatch back car so the bass comes out better.
  • Who's Online   1 Member, 0 Anonymous, 780 Guests (See full list)
