Car's Totalled, Time To Rebuild!
First and foremost, pictures of the old car post-accident:
Pictures will be uploaded as i go, as this will be a medium/slow timed build. I will also try to keep this as organized as possible., and cross off parts when they're done or installed
This is a list of what my new build will consist of:
Vehicle:
Chevy Cobalt, non SS, have yet to purchase as I'm waiting on the check for my old vehicle
Audio:
Sony XAV-601BT (Owned)
2x Digital Designs Z1's (1 owned)
2x DD 9512 i series SC (Owned and installed)
lots of Deadener/Spectrum/Sludge/Expanding Foam
lots more 1/0
2x TI Baskets (no longer using)
2x 8" DD platinum carbon dust caps (owned)
2x DD VO-M8's (1 per door) (owned)
1 set of DD 6.5" component set (owned)
1 DD S4 4chan (owned)
4-5 G31 batteries (3 owned and installed)
Vehicle Accessories:
K&N cold air intake
H/O alt (220a)
Projector headlights
SS Spoiler (no longer using, as it will break/flex too much)
plasti-dip the car a flat white
OEM Aluminum 5 spoke 17" rims plastidipped also
Smoked LED tail lights
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
you can buff that out. might need one new tire though. otherwise, fine.
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
15 gallons of Bondo and you should be all set
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
i was doing 146.93db @ 28hz with 2 DD 9512B's on the Z1 wired to .5 in the riviera.
got pretty nasty, but i want louder, and competitive numbers ;)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
moar pics:
ti baskets
cadence 7 band EQ
kicker 300a fuse block (for MECA shows)
LC-1
couple of toggle switches
red Stinger volt meter lens *will be using blue LED volt meter (makes it purple in color)*
couple of fans
DD CS-6.5" component set
DD Crossover (another needs to be bought. Other was trapped in the driver door)
2 8" DD Platinum carbon caps
6x 1/0 to 4awg reducers by toolmakerz
DD Z1
DD S4 4channel
lot of 1/0 and 4gauge wiring (also a bit of 3/0welding ;D)
3 AGM group 31's
2 small distro's
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
somethin came in the mail yesterday :o
one has an aluminum spacer, one doesn't, so ill be ordering another spacer, and possibly having them SC'd, still have to decide on that part
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
hold on... that magnet came in the mail? How big of a mail box you got?!
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
