Tribe Called Bass Posted September 7, 2013 Report Posted September 7, 2013 So i'll be having 4 d3100's in the trunk, and one in the front. I'll be putting 2 runs for each battery(8 runs + speaker amp, so 9-10 total) I'll be fusing each ends, but I'm wondering is, would it be easier to have A distribution block under the hood to limit the amount connections to the front battery? Or go with A bus bar?
Miguels Posted September 7, 2013 Report Posted September 7, 2013 you dont need that many runs of wire not unless you are running quad alt install.. what is the alt you will be getting? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Tribe Called Bass Posted September 7, 2013 Author Report Posted September 7, 2013 you dont need that many runs of wire not unless you are running quad alt install.. what is the alt you will be getting? A Singer 230. Powering A DC 5k.
Miguels Posted September 7, 2013 Report Posted September 7, 2013 are you running cca or ofc? 3 runs is more than enough. 4 is overkill and 8 is beyond overkill. nothing wrong with overkill but why spend money where is not needed.. save on wire and get an extra battery. it will help you more then having 5 extra runs of wire you dont need my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Tribe Called Bass Posted September 7, 2013 Author Report Posted September 7, 2013 are you running cca or ofc? 3 runs is more than enough. 4 is overkill and 8 is beyond overkill. nothing wrong with overkill but why spend money where is not needed.. save on wire and get an extra battery. it will help you more then having 5 extra runs of wire you dont need OFC, I'm guessing it's better to wire the batterys together, then on the last one run the multiple runs to the front? I was thinking of running multiple runs for EACH battery to the front hahaha. $170 for 50ft. ARGHH!
twisted1 Posted September 7, 2013 Report Posted September 7, 2013 im running bus bars. I was having a problem with low voltage in the 12.7 while running when i first did mine though.. The problem was i grounded the batts to the cab, but i have a body lift so my truck sits on these plastic blocks now. Well after a couple days i decided to cut a hole in the cab an wire ground lead to the frame, and shazam im back at 14.4 volts running 09 mustang gt
