czman30 Posted September 9, 2013 Report Posted September 9, 2013 Hello, I've really been stumped on this for a while now. I have the dimensions of the box I want but I really don't have the time or money to mess this up so I am wondering what should the port area be if I have a box that is 40in width, 18in height, and 24inch in depth with 1 inch mdf? Also when you have a port and need to maintain the port width and if you were to make a right angle and continue how do I figure out the port length? Currently on iPhone will post picture of what I mean later if what I am saying isn't making sense! Any help is appreciated! Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
TheMonolith2001 Posted September 10, 2013 Report Posted September 10, 2013 Can you make it a bit bigger? Joe X designed this box for me and its fantastic: http://www.stevemeadedesigns.com/board/topic/151485-fi-q-18-box/ I used 3/4 inch but instead of MDF I used Birch. I braced it with a LOT of really thick metal L brackets and shit tons of industrial liquid nails. Then sealed it further with silicone seal. I can be blasting test tones at full volume and feel zero vibration anywhere on the box. Its heavy as fuck though. Sounds very good
czman30 Posted September 10, 2013 Author Report Posted September 10, 2013 Can you make it a bit bigger? Joe X designed this box for me and its fantastic: http://www.stevemeadedesigns.com/board/topic/151485-fi-q-18-box/ I used 3/4 inch but instead of MDF I used Birch. I braced it with a LOT of really thick metal L brackets and shit tons of industrial liquid nails. Then sealed it further with silicone seal. I can be blasting test tones at full volume and feel zero vibration anywhere on the box. Its heavy as fuck though. Sounds very good I went with 42width 18 height, and 24 depth. 6x16 port which comes out to 96 Square inches. I was going to add some bracing... but im afraid its going to mess up all my all of designing which I have gone back repeatedly to redo... and I dont have much more time before I need to start building it. Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
czman30 Posted September 11, 2013 Author Report Posted September 11, 2013 This is what i plan on building Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
TheMonolith2001 Posted September 11, 2013 Report Posted September 11, 2013 Yeah that is more or less what mine looks like. When half your box is port panels its already being braced quite a bit
czman30 Posted September 16, 2013 Author Report Posted September 16, 2013 I have something else to add to the Topic, So does it actually help to resin your box? I would like some feedback! Thanks Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
czman30 Posted September 22, 2013 Author Report Posted September 22, 2013 Going to get the MDF today, 3 sheets of 1/2 MDF. I plan on taking pictures and making a build log. Bass here i come! Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
john253a Posted September 22, 2013 Report Posted September 22, 2013 Don't do 2x 1/2" to make 1" Either use 3/4 and double the top or 1" all round 1/2 with a double skin just doesn't cut it If you want to do 5/8 if that how you plane to build
TheMonolith2001 Posted September 23, 2013 Report Posted September 23, 2013 I'm not sure about the resin thing. Everything I have read about it seems to suggest it is a good idea but it looked a bit too complicated/messy for me. I am not very good with anything wood related. Good thing I had access to people who could do that cutting well for me. From what I understand what you are essentially doing is sealing gaps in the wood/making it harder or at least giving the sound a stiffer surface to bounce off of. I felt like a more efficient solution to this was to use a less porous wood (AKA something that is more wood and less glue) and a harder wood so I built my box out of birch instead of mdf. Now if you build the same box out of MDF+Resin and compare it to mine on a termlab or something I have no idea who would really win but I would imagine I am at least somewhere in between doing nothing about the problem and the resin box if not just as effective and doing it by just buying a different box material required no extra work.
czman30 Posted October 4, 2013 Author Report Posted October 4, 2013 Just glued my sheets up. I cut the full sheet up into peices. Now I glued up the sheet I cut in half. I will post pictures of the peices later. Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
