90 amp alt, 2 batts?
i have a 90 amp alternator on my 2011 kia sportage, currently have one yellow top optima up front and thinking of adding another one or 2 in the back.
would my 90 amp alt be able to keep the one up front and maybe one more in the back? already done big 3... voltage drops to about 12 when playing full tilt
Pioneer AVH3200 DVD
2, Pioneer 6.5" 2 way 60 Rms Kevlar
4, Pioneer 6x9 2 way 80 Rms Kevlar
1, Kicker Solo-Baric L7 15-Inch 1000 Rms
1, 1000Rms Hifonics Monoblock Amplifier
1, 800Rms Hifonics 4-Chan Amplifier
Audio Control Epicenter
Kicker Kx3 Crossover
120AH Power cell Battery (Main)
Pioneer AVH4300 DVD HU
2, 500rms D.A.S 10B 10' Mids
2, 500rms D.A.S 8' Mids
2, 300Rms Pyramid TW47 2" Super Tweeter
2, SA-12 D4 Tuned @ 33hz @ 4.26 ft^3
1, 1000Rms Rockford Fosgate T1000bdCP Amplifier - Birth sheet 1576Rms
1, 1000Rms Rockford Fosgate T1000-4AD Amplifier - Birth Sheet 1496Rms
Audio Control ESP2
Clarion Mcd360 Electronic Crossover
Kicker KQ30 30-Band Equalizer
Rockford Fosgate Rfc10hb 10 Farad Hybrid Digital Capacitor
Yellow Top Optima (Main)
Big 3
I say you should be fine, if you're holding 13's with a 2nd batt, that means it's balanced between alt and batt power, and batts won't be drained, now if you stay on 12's often, then I'd invest in a battery charger, and charge the batts at least once a week.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
adding more batteries doesnt mean you wont have drop.. it will be okay for a few seconds then it will drop back to 12 and you will have dead batteries in a few days
i was hoping it would at least keep the voltage in the 13's im not always playing full tilt, wouldn't they charge back up when im not through the alt? im playing full tilt for maybe 2-3hrs a week total...
Pioneer AVH3200 DVD
Audio Control ESP2
Big 3
Exactly
OP, If you're seeing 12 volts often, you're solely relying on battery power. Adding a 2nd battery does help when you're running over 1000 watts, and sometimes, your voltage drop will decrease because you have enough battery power to maintain voltage, but the alt is equally important as well.
2003 Kia Sorento
Team Subsonic Lows
i fully understand about the alt... just want a easy fix for now, ill give it a try n see what happens with the second batt...
Pioneer AVH3200 DVD
Audio Control ESP2
Big 3
Running more batts always help, just gotta make sure they are properly charged :) (and in good shape)
2003 Kia Sorento
Team Subsonic Lows
it can, but it takes time. what your alt does is charges your batt(s). And of course, the batt being charged (up front) has to charge the back ones, and before that is done it has to be fully charged. your best bet is getting a new alt if you plan on running that much power. I recommend excessive amperage alts.
2003 Honda Element
Pioneer DEH-9400BT
Big 3
XS Power D5100
Sky High CCA (2 Runs 1/0 Gauge)
2 XS Power D3100s
1 DC Audio 3.5k @ 1ohm.
2 DC Level 4's w/ XL Softies
Custom Box tuned to 29hz
CT Sounds 125.4
2 Sets of CT sounds Meso Components
*North East Frequencies*
