Ryan_Kao Posted September 14, 2013 Report Share Posted September 14, 2013 PLEASE HELP ME. WHAT AM I DOING WRONG?I got my meters out today and decided to clamp to see my RMS. I hook my positive and negative leads of the MULTIMETER to the positive and negative of the speakers outputs on my Soundstream DTR1.900D Rated for 900Watss RMS @1ohm. YES IM AT 1OHM. Then I hooked the CLAMPMETER to the positive wire of the speaker outputs. This is what I got... I was playing a 40hz test tone at my max listening volume, gains are set to not distort on the amp. The sub was at damn near full stroke (max excsursion) as loud as i would be burping. It hurt my ears to sit in the car to rev the engine. WHAT IS WRONG?!??! Build in progress: -Pioneer Premiere DEH-P49OIB _Kenwood Excelon KFCX173 6.75" -Kenwood KFC-1094PS 4" -DB Link 4AWG -Soundstream DTR1.900D -Obsidian Audio v2 12" D2 @1ohm -L-Port, 2.5cubes @32hz CHECK ME OUT ON YOUTUBE Link to comment Share on other sites More sharing options...
Omega5002 Posted September 14, 2013 Report Share Posted September 14, 2013 Maybe you have crazy high box rise 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
Tarball Posted September 14, 2013 Report Share Posted September 14, 2013 what is your box tuned at ? CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
k3n12ock Posted September 14, 2013 Report Share Posted September 14, 2013 My bc3500 only clamped 749 watts 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
Wicks Posted September 14, 2013 Report Share Posted September 14, 2013 1.). Clamping is not a reliable way to measure amplifier output. 2.). You're looking at one frequency, try a sweep. 3.). At resonance, the impedance of your sub rises greatly so it would naturally reduce amplifier output. Doesn't mean your sub outputs less, as you've stated. 4.). Check out Tony D's vids on clamping. 5.). Hard to tell on mobile. If you have multiple wires from your sub terminals, make sure all wires from the same polarity are through the clamp meter. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
fox_racin4 Posted September 14, 2013 Report Share Posted September 14, 2013 7.16ohm FTMFW!!!! 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
ham4864 Posted September 14, 2013 Report Share Posted September 14, 2013 After i found out the clamping is not accurate i want to send my amp to Steve for a dyno run. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
Tarball Posted September 14, 2013 Report Share Posted September 14, 2013 1.). Clamping is not a reliable way to measure amplifier output. 2.). You're looking at one frequency, try a sweep. 3.). At resonance, the impedance of your sub rises greatly so it would naturally reduce amplifier output. Doesn't mean your sub outputs less, as you've stated. 4.). Check out Tiny D's vids on clamping. 5.). Hard to tell on mobile. If you have multiple wires from your sub terminals, make sure all wires from the same polarity are through the clamp meter. ^^^ Edit - nice, I intercepted a double post!!! CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
Ryan_Kao Posted September 14, 2013 Author Report Share Posted September 14, 2013 Huh, thanks for the responses guys! Box rises makes sense. The box is 2.5cubes at 32hz. Whats an accurate way to tell amp output without steve's Dyno? Build in progress: -Pioneer Premiere DEH-P49OIB _Kenwood Excelon KFCX173 6.75" -Kenwood KFC-1094PS 4" -DB Link 4AWG -Soundstream DTR1.900D -Obsidian Audio v2 12" D2 @1ohm -L-Port, 2.5cubes @32hz CHECK ME OUT ON YOUTUBE Link to comment Share on other sites More sharing options...
Omega5002 Posted September 14, 2013 Report Share Posted September 14, 2013 a non reactive load on the amp 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
