will 2 ohm bridging work with this amp
bassman619
I have a memphis mc4.75 4 channel amp.. I am getting a set of re audio xxx 6.5 components. They take 150w rms and 300w peak each but thes comps are 2 ohms impedance. I have this in my car now hooked up to some mclass 6.5s and I have done research on this amp. What I found is you can bridge the amp to get 2x 230watts rms at 4 ohms. Youcan also put a 2 ohm load on each channel to get a 4 x 115w rms..but what I want to do is bridge it but I dknt know if that is possible with this amp. Can some one tell me if it can be done?
You need trunk space to get groceries and shit...bitches love groceries
Yes that amp is 2 ohm stable. just be careful they tend to run a little hot.
2 ohm stable only when each channel is loaded to 2 ohms.
When you bridge a 2 ohm load on a 2 channel amplifier (a 4 channel amplifier is 2 2 channel amplifiers together for simplicity's sake) each channel will see the resulting load as 1 ohm.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 951 Guests (See full list)
