A-Pillar Speaker Placement for Sound Quality?
Wicks
Ok ... The real reason people sound deaden their vehicles is to lower the noise floor ... Once that goal is reached, there will be no need to worry about peaks or cabin gain ... Reflections will need to be worked out with driver aiming and positioning (mainly your tweeters) ... Then once you've acquired time alignment, placement correction, and equalization capabilities ... Then we will get to the subject of stage and image ...
Music will start really making since when you start establishing those goals
  • 3 weeks later...
OK...........more questions.
I have a Denon home audio receiver with time alignment that uses an external microphone to automatically set the time delays.
Very handy to let the receiver determine the correct settings (at least initially).
So,
I don't see microphone inputs on any of the HU or processors with time alignment, only adjustable manual time delay settings.
Adjusting the time delay for speakers that are on-axis is simple and obvious, but what about having your tweeters off-axis?
Do you still measure the physical distance between the tweeter and your ears (or desired focal spot) or do you approximate a longer reflection path and use that?
Or do you generally have to just start with some initial settings and just tweak away until you find the magic formula?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
fully ative means exact measurements from every driver to the listner's seating position ... and I mean EVERY independant driver, including your subs ...
there is a mathematical formula for it ... you start with the driver furthest away from you and measure each one out until you mathematically have all drivers in time alignment with each other AND to the driver seat / listening position ... then its all about the EQ side of things ...
I got counted off points in the last MECA event because my subs were not in correct time alignment with my midbass drivers ... Yes, it was my fault, I gave a demo before judging and forgot to reset back to normal judging settings ...
I'm in the process learning this with my Kenwood, but I hear that each headunit / processor reads different ...
I understand the basic technique for measuring the physical distance between all drivers and the listening position in order for the processor to add the appropriate delay.
Tweeters are very directional. So if you have them mounted way off-axis then I was curious if you still just measure the physical distance or whether you measure the acoustical path since the main on-axis lobe needs to reflect off of a surface(or two) of your vehicle to get back to your ears....?
Or do you not care about the main on-axis lobe and only concentrate on the attenuated off-axis lobes?
...if that makes sense?
Out of curiosity, why demo with the subs and midbass out of alignment? I can see tweaking the EQ settings to squeeze out some more bass for a demo, but I would figure you'd always want everything time aligned?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
They were close, but not really ...
Time alignment in my truck puts the bass more up front and up on the dash ... Great for SQ. But kinda takes away aggression during the SPL stuff (dubstep) ... Or maybe I just don't have it set up correctly yet ...
For my truck ... The outlaw bass is much more aggressive with the time alignment (subs only) turned off ...
On axis ... I enjoy it
Off axis ... I enjoy it ... Hard to say what I really like better
I'm assuming (cause it is what was done to mine) you treat them the same and tweak and tune from there ...
Very interesting!
Good to know as I'd probly demo in the same way, an SQ setup and then settings for something much more aggressive.
I'll keep that in mind when I get to that point.
Since I'm new to everything truly SQ, I thought I'd start simple and just go with an on-axis setup.
When I get more experience in what to listen for, then I can integrate the speakers in an off-axis setup and get more creative.
For now I'm leaning towards this:
A couple small custom pods in the far corners of the windshield.
Each holding an HT25 Hertz tweeter and I see that Hertz makes a 3" HL70 mid that should fit up there perfect. I was thinking about my HV130 5.25" mids but they're way too much for that location.
Then the Hertz HV165 6.5" down in the bottom of the door, sealed in its own pod.
I think the 3" mid would make a great transition between the tweeter and the 6.5".
If they're too much, I can always attenuate them or switch them off, but it'd be nice to have them there when I want them.
Then there's my ES200 8's that I'd love to integrate as well.
I was intrigued by Meade saying he turns his SMD15 way down and mainly uses his 8's for SQ demos. Then turns up the SMD15 otherwise for the more aggressive demos.
I know in SQ that less is more, but I'd rather have the extra drivers available and turn them off rather then wish I had them when not in SQ mode.
Sooo much to think about........Hmmm
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
From what was told to me ... the "on-axis" is the more advanced option ...
once you go "on-axis" ... there will never be a need for anything "off-axis"
unless you are like me and just really want to go back to a simple 5.1 setup when the 49 Ford is ready for audio ...
I am learning this now ... in very detailed and critical listening music, unused drivers that are installed in the vehicle have no so called "driver control" and has the potiential to react as a passive radiator ... please be very carefull with this, cause it can hurt you just as much as it can help you ... Even with my Sub Stage upgrade, they will be active and time aligned to prevent anything like this from happening ... and every unused driver is removed (center channel ...etc) for Critical Sound Quality judging ...
I know guys, this is going a bit far here, but SPL guys do EVERYTHING they can to get that extra DB that might win them a World Title ... Well, Same way for Sound Quality when less points are counted off --- the Better the Score !!!
On-axis is more advanced...? I would have thought fighting the off-axis reflections would be more difficult...
I am quickly seeing why SQ is so complicated.
The main need for off-axis that I was thinking of would be a more stealth install (don't have a set of speakers aimed right at you).
SHIT.......... That had come to mind, that unused drivers could cause a passive radiator situation and cause issues. Fantastic point.
Makes sense, you can't REALLY have it both ways. SQ vs SPL.
Thanks for all the advice Randal.
I'm going to have to take all that into account, dive in and see what I can do. :good:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
  • Who's Online   0 Members, 0 Anonymous, 2011 Guests (See full list)
