jmfrb1 Posted September 20, 2013 Author Report Posted September 20, 2013 I already have the PVC 8" diameter by 35" long. I didn't pay anything for it but I'm taking my time on the build so I don't have a problem with that. And I wasn't sure if the wall mart heat gun would get hot enough. But if it does then I'll definitely shell out 20$ n go that route! Would boiling the pipe work?
jmfrb1 Posted September 20, 2013 Author Report Posted September 20, 2013 You have to heat the pipe some way or it will never flareThis is why I was thinking about boiling the pipe. but I'm not sure if that works or not.
SnowDrifter Posted September 20, 2013 Report Posted September 20, 2013 Not sure boiling the pipe would get it hot enough. Harbor freight has a heat gun on sale right now though. $10 iirc You may also find this a good read. Goes a bit beyond the bowl method http://www.subwoofer-builder.com/flares-25mm.htm ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
mothra Posted September 21, 2013 Report Posted September 21, 2013 Depending on the flare you could use a door panel router bit instead of a round over. if nothing changes, nothing changes You don't know what you don't know, till you don't know
