So here is a thought. Should I just get rid of the 6x9s in the rear deck? Then I could fill it in with deadener and use all the power of the 4 channel amp to run my mids and highs up front. I read on here a lot of people don't do rear mids because the woofers will drown them out anyway, so that would be a waste of 120 RMS power that I could add to the front stage. Of course, I would then have to upgrade my front comp set to something that can handle 120RMS on each side.
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
Do front. Even with my small temp amp and subs I can't hear my rear fill. Rear fill is a waste IMHO
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Crescendo mezzo take 150 rms and are currently $40 off trough the crescendo store
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
I turned off the rear fill in mine, no need for them and sounds better with just the fronts. Gives you more of a budget to do something sweet for the frontstage as well :)
1898070_635754349830843_1457278514_n_zps
Oh yeah, Fed Ex just stopped by with goodies!
Got some more goodies today!
Going to install the alt bright and early in the morning. The subs and amp are going to sit a while until I bring my funds back up and decide on a box. Still need to decide on front stage too, but not worried about it without any extra cash to spend anyway.
Mechman 240 is installed and charging.
Doing a little metal fab for my VM-1 today.
Wired up and mounted
