Weak bass
Antonio Moore
So I switched Amps from kicker 1500.1 to an saz1500.1dv2 so I can wire my 2 sa 15s d4 to a 1ohm load
I also installed an xs power battery d1400
I rewired subs from 4ohm load to 1ohm. Charged the xs battery for about an hour because I thought maybe the battery was dead I noticed the bass a bit stronger after doing so but it's still plays weaker than on my stock electrical system
Does your car have a stock 14v/16v charging system?
OP, are you sure you got a D1400? Because that isn't the right battery for your vehicles electrical.
12v system. I would check your wiring or gains honesty. How did you set your gains?
If in fact you have a D1400 hooked up to a stock electrical system, the D1400 being a 14v battery, and not a 12v battery which is what you most likely need, the voltage that your stock alt will charge at is considered low voltage almost for a 14v battery which is usually charged by 15.9v. Your 12v system charges at around 13.5-14.8v. Aka, wrong battery application
  • Who's Online   0 Members, 0 Anonymous, 6054 Guests (See full list)
