Jacob macri Posted September 23, 2013 Report Posted September 23, 2013 So i'm installing a shuriken BT 120 battery and a TA1.3000.d for my new upgrade. running 1/0 wire i want both the extra battery and amp to be in the trunk along with the subs. I have a 2000 escalade. I have the trunk liner off so bolts are exposed as you can see in the picture. obviously these bolts and be loosened and they are pretty secure it seems like they are attached straight to the frame. I was wondering if these would make nice grounds? they would sure as hell be convenient. thank you pics below.
soundstream15 Posted September 23, 2013 Report Posted September 23, 2013 If they go to frame then sure. Otherwise ground to front battery
Jacob macri Posted September 23, 2013 Author Report Posted September 23, 2013 If they go to frame then sure. Otherwise ground to front battery gotcha. I'm just trying to save wire you know?
john253a Posted September 23, 2013 Report Posted September 23, 2013 Wire's cheap Compaired to amp if you don't supply enough juice
