Sergeant_Skyrim Posted September 30, 2013 Report Posted September 30, 2013 Just trying to do some more research before I do purchase another alt. Tried googling to see if anybody anywhere has ever installed a DC Power Alt on a 2.2L Ecotech Cav and didn't return anything. Called up DC Power though and feel pretty confident that their 270 should work but I'm wondering if anybody on this forum has any first-hand experience with this car and a dc power alt? My only concern is that since it idles at about 500-550 engine RPMs hot, it either won't be spinning fast enough to turn on or it won't be putting out enough amps to run the car (not including any aftermarket stuff, only car computer/accessories). Had this problem with the Singer unit which ran perfectly once I hit 750-800 engine RPMs and turned on but I need something that will be useful on a daily driving basis Thanks for reading, hoping at least one of you awesome bassheads can chime in! Build in progress
Guest DC Power Kyle Posted September 30, 2013 Report Posted September 30, 2013 The alternators turn on way lower than 550 RPM. My car idles at 550-650 on my camry without any issues. I've never EVER had a customer return anything because of no idle output on an XP. Take it with a grain of salt. Hopefully someone will chime in.
Guest DC Power Kyle Posted September 30, 2013 Report Posted September 30, 2013 two very VERY old pictures I took.
Sergeant_Skyrim Posted September 30, 2013 Author Report Posted September 30, 2013 Hey Kyle, I actually just talked to Andrew I believe his name was (said he wasn't on the forum like you). I'm most likely going to end up buying the 270 at some point this week just figured I'd check if anybody's had experience with the same car. I did forget to ask though, is it a direct bolt on unit and same belt size as stock? Edit: Well damn lol, that makes me feel a lot more confident. Build in progress
Guest DC Power Kyle Posted September 30, 2013 Report Posted September 30, 2013 Direct bolt in. May need to replace the belt.
Sergeant_Skyrim Posted September 30, 2013 Author Report Posted September 30, 2013 Sweet, you guys can certainly be expecting an order for an alt + a t shirt by the end of this week! Build in progress
Tarball Posted September 30, 2013 Report Posted September 30, 2013 Make sure to get the "XP" mentioned by Kyle. Other series may (or may not) have an issue. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
