MARKMC@GMAIL Posted October 1, 2013 Report Posted October 1, 2013 Right now I currently have a hifonics brx2400 and 2 kicker l7 dual 2ohm 12's. But when I get my vehicle I'm gonna have a kicker 2500 amp and aftermarket alternator. Should I get a 300 amp alternator and what battery should I get exactly looking at xs batteries.
Jessica Posted October 1, 2013 Report Posted October 1, 2013 With that amp if you get a 300amp alt you will only need one batttery. Just make sure to do the big 3. Even a stock battery would cover it. If you want a better battery and want the best you can get for the money get whatever XS is a direct fit replacement for you vehicle. For a cheaper alternative, and if it will fit. a Deka group 34 is a good deal at around $160. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
HHR Ed Posted October 1, 2013 Report Posted October 1, 2013 Going 14V or 16V takes a lot of customization to the electrical. For reliability, ease, and budget I recommend staying 12V. Also, alternator size depends on what is available, what your budget is, and what batteries and power level you choose. So you are going to have a 2500w amp. This will consume about 3500W. One big battery such as an XS Power D3100 can handle that. Or a smaller battery for the engine and a 2nd, supplemental battery. So even if you have 2 big batts. An alternator around 200-270A will do wonders. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
MARKMC@GMAIL Posted October 1, 2013 Author Report Posted October 1, 2013 I wanted to go with a second battery just for my amp in the back. Just want to make sure I get the right battery and alternator to have my system running smooth and not destroying anything. I'm trying to go with the cheapest but has real good quality
Omega5002 Posted October 1, 2013 Report Posted October 1, 2013 12v battery if you're charging from 13.5 - 14.8 14v battery if you're charging from 15.5 - 16.816v battery if you're charging from 17.5 - 18.8 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
HHR Ed Posted October 1, 2013 Report Posted October 1, 2013 12v battery if you're charging from 13.5 - 14.8 14v battery if you're charging from 15.5 - 16.8 16v battery if you're charging from 17.5 - 18.8 2.4V per cell for AGM. 12V = 6 cells = 14.4V 14V = 7 cells = 16.8V 16V = 8 cells = 19.2V Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Soccerballzs Posted October 1, 2013 Report Posted October 1, 2013 Go with XS D3100. Heavy and can keep up with power demands. Quality and cheap does not go in car audio. Example Bullz Audio wire VRS Skyhigh Wire. Bulls cheaper Shyhigh more money but much better quality. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Omega5002 Posted October 1, 2013 Report Posted October 1, 2013 12v battery if you're charging from 13.5 - 14.8 14v battery if you're charging from 15.5 - 16.8 16v battery if you're charging from 17.5 - 18.8 2.4V per cell for AGM. 12V = 6 cells = 14.4V 14V = 7 cells = 16.8V 16V = 8 cells = 19.2V Thought 12v agms could charge at 14.8 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
HHR Ed Posted October 1, 2013 Report Posted October 1, 2013 12v battery if you're charging from 13.5 - 14.8 14v battery if you're charging from 15.5 - 16.8 16v battery if you're charging from 17.5 - 18.8 2.4V per cell for AGM. 12V = 6 cells = 14.4V 14V = 7 cells = 16.8V 16V = 8 cells = 19.2V Thought 12v agms could charge at 14.8 AGM cells should charge max 2.4V per cell. Minimum about 2.2V per cell. So AGM charge limits are 12V = 13.2V - 14.4V 14V = 15.4V - 16.8V 16V = 17.6V - 19.2V Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
MARKMC@GMAIL Posted October 1, 2013 Author Report Posted October 1, 2013 Go with XS D3100. Heavy and can keep up with power demands. Quality and cheap does not go in car audio. Example Bullz Audio wire VRS Skyhigh Wire. Bulls cheaper Shyhigh more money but much better quality. Won't I need a bigger alternator for this battery
