Kidd_Bass Posted October 4, 2013 Author Report Posted October 4, 2013 is it the sable gs or the sable LS premium? if it is the LS premium is it the 4 speaker or 6 speaker? LS premium 4 speaker
Soccerballzs Posted October 4, 2013 Report Posted October 4, 2013 Make a template of doubledin unit. Remove dash front remove radio then glass your din template in. Then use interior paint to match. Seen it done before. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Kidd_Bass Posted October 4, 2013 Author Report Posted October 4, 2013 Make a template of doubledin unit. Remove dash front remove radio then glass your din template in. Then use interior paint to match. Seen it done before. Yeah but my AC controls and outside climate monitor are built into my radio unit
Soccerballzs Posted October 4, 2013 Report Posted October 4, 2013 You sure its not to seperate units. Dremel straight line for bottom of radio. Are the any parts in junkyard with C.D. Then 3Sixty3 http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Tecomah Posted October 4, 2013 Report Posted October 4, 2013 I am trying to think of a way for you to do it. Will the stock radio not work right if nothing is hooked to it from the back speaker wise. Then you could extend the connector out and connector to the new head unit 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
Kidd_Bass Posted October 4, 2013 Author Report Posted October 4, 2013 You sure its not to seperate units. Dremel straight line for bottom of radio. Are the any parts in junkyard with C.D. Then 3Sixty3 It's all 1 part I already pulled out the unit before thinking I could just dremel off the top and glass the the top portion for a radio
Kidd_Bass Posted October 4, 2013 Author Report Posted October 4, 2013 I am trying to think of a way for you to do it. Will the stock radio not work right if nothing is hooked to it from the back speaker wise. Then you could extend the connector out and connector to the new head unit If I unhook the cable behind the radio the unit completely shuts off and so does the AC controls
Tecomah Posted October 4, 2013 Report Posted October 4, 2013 Well then this process gets a bit harder. You can make you own connector remote, ground, 12v and all the speakers and run your own wires. If you go through that much work I would swap the stock speakers out while you were at it 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
g2shuck Posted October 4, 2013 Report Posted October 4, 2013 maybe this? then you can integrate your sub amp, and later if you want also a 4 channel amp to power nice speakers. This is way better than a standard line out convertor. http://www.sonicelectronix.com/item_8168_AudioControl-LC6i-WHITE-LC6.html 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
Kidd_Bass Posted October 4, 2013 Author Report Posted October 4, 2013 maybe this? then you can integrate your sub amp, and later if you want also a 4 channel amp to power nice speakers. This is way better than a standard line out convertor. http://www.sonicelectronix.com/item_8168_AudioControl-LC6i-WHITE-LC6.html that looks good do you think i could add a auxiliary port to it some way
