I've installed this system almost a year ago and everything was going fine until last week. My Amp stop working and I can't find why, the rest of the systems work fine. I've checked if it was blown by giving the remote wire power with a jumper from the Amp power source and when I've turned my radio on my amp turned on so as my Sub .Then I've checked behind my radio unit if I had any power from my Remote wire output and I don't. I've also checked my amp and radio unit fuses and they are fine.
One thing that I've done last week on my car was installing HID and when I was plugging back the battery it made sparks, and also my unit reset it self for some reason while I was driving.
Is it my unit that has a problem and is it repairable or do I need a new one.
Thank you for your help.
System:
- Unit : JVC KD-S88BT
- Amp : Alpine Mrp-m500
-Sub :2x kicker Comp 10''
Check your fuses. You may have blown one when you sparked the battery. In-line fuse on your power wire maybe??
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
You may need to set all inputs etc on head unit since it lost power.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
My in-line fuse is fine, and I've gone trough the head unit manual there's no setting to chage it I also tried everything in the settings that can be related and no luck.
Check your grounds
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
You answered your own question.
If the remote does not have power, the amp will not turn on.
Take a jumper wire from the + side of your amp INPUT (not the speaker leads) and jump it over to the remote turn on input of your amp and see if it turns on.
If it does, then your remote wire is bad. The fact that there is no power from remote tells you already that your remote is bad. Something is wrong there.
EDIT: you already jumped the wire and it turns on and plays? Then again, your remote out is bad. You can try using the red wire from your head unit instead and see if it works. Just make sure your amp turns off when you turn the ignition off.
Eclipse cd7000
There's not a sub on/off setting on your deck?
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
