Hifonics GLX1400.1D clamp test?
G-Rad
My cousin and I have been working on a 2007 Ford Focus and right now I have a decent rig going. But, I want to know what the amp I'm u sing to push my 2 MTX Thunder T7512-04's is really doing. Has anyone clamped a Hifonics Gladiator GLX1400.1D? Right now the amp is running at 2 ohms, and says it does 1,000 RMS x1 @ 2 Ohms. However, these MTX 12's are fairly loud, but are barely moving. (The woofers are actually still quite stiff). This is why I wonder what the amp is really doing. If anyone has tested this, please let me know. Thank you.
BASS MEKANIK RECORDS
"Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold!
2007 Ford Focus
(NOTE: My cousin's build I helped him with)
Pioneer H/U
(4) Absolute Dome Tweeters on A & C pillars
Scosche HD683A's in front doors
Fosgate R168x2's in rear doors
SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz
Audiopipe APCL-1800.1D
Q-Mat
Audio Technix 0 Gauge
119aH/850CCA Marine Deep Cycle batteries
YouTube Channel: http://www.youtube.com/DWRhythm
RMS Power @ 4 ohms500 watts x 1 channels
RMS Power @ 2 ohms1000 watts x 1 channels
RMS Power @ 1 ohm1400 watts x 1 channels
Amplifier Specifications
Amplifier ClassD
Number of Channels1 - Mono
Total RMS Power Output1000 watts
This is from sonicelectronix.com so seeing its total rms is 1000 and it has 2x70amp fuses I would guess its probly only pushing 500wrms total to both subs. So each may be getting 250-300rms on a good day with great electrical since hifonics likes a lot of power. No I have not done a clamp I'm just using the info from sonic and the fact that that line of hifonics does not do rated power.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
The general rule of thumb is 10a for every 100w, so 2 70a fuses = 140a, amp does 1400 RMS, so I"d have to guess that it's probably not doing exactly that since there is drop and everything in voltage. I'd be happy to see if it even does 800 at 2 ohms. But 500 is rather low IMHO, but then again, I wouldn't be surprised. It's not a BRX or BRE series.
2007 Ford Focus
Pioneer H/U
Q-Mat
Most of the hifonics that have been tested have been the BRZ or BRX line and yes they do rated but are power hungry like a SOB. the gladiator line i have heard does not do rated and puts out dirty power. But if you want to know you can see send it to some one with a AD-1 and have them test it for ya.
141 on music.
Well you've heard wrong
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
We'll facts are facts from what sonic said any way. 1000wrms at 2ohms and 1000wrms total output so to me that means 1000wrms at 1ohm thus it should be about 500 at 2ohms. I just don't understand why it would say 1400wrms at 1ohm then say 1000 rms max
141 on music.
  • 4 weeks later...
This amp says it's CEA compliant, so I would expect to see dirty power for the last 100-250 watts or so. I'd have to assume it's underrated by that factor in clean wattage.
2007 Ford Focus
Pioneer H/U
Q-Mat
The last hifonics amp thst went on the dyno didnt do rated but yet every person thst ran it still found a way to try ro justify it. Oh look at 15.8 volts and in uncertified burst mode it barely made rated power
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Also cea compliant doesnt mean much. They dont test every amp or line that comes out
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Steve tested a Crunch DRA1150.2 that had 70 amps of fusing and only did 200 something watts. Crunch is made my MaxxSonics. Guess who makes HiFonics???
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • Who's Online   0 Members, 0 Anonymous, 656 Guests (See full list)
