smd distortion detector Raleigh nc
Does Anybody in Raleigh NC has a smd distortion detector so I can get a properly tuned system. I had my system tuned by three different shops and they all tune my system by ear and the result was clip city that leads to burnt up woofers .my system consist of 4 pioneer 6.5 speakers and 4 pioneer 6x9 for highs run off of a crescendo 1100.4 and 2 phoenix gold ti2 15s run by a crescendo bc2000.
Lots of bassheads, just no ddm. I've been looking for one as well but the closest I've got was near Jacksonville or SC.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Yea I'm in Fuquay so like 10 mins from Raleigh...but sadly no ddm :(
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
I know you can set it using a volt meter and some math. Take the watts the amp will put out times the ohm load and them take the square root of that number. So a 500w amp running at 2 ohms is 1000 then take the squared which is 31.62v. That is the number that will be coming out of the speaker terminals. Just disconnect the speaker wires and put the meter prongs in and play a test tone with the HU volume up 3/4 of the way and turn the gain up till the meter reads the correct voltage.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
DMM is not accurate. Ballpark the gain on the low side until you can get the proper tools to set the gains. DD-1 or 'scope
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 3341 Guests (See full list)
