A question on Sub quantity vs variaty
I have noticed most of you guys have x4 (or more) subs of the same size. Is this for pure spl reasons? I am plannin on building a wall section on a 2006 Nissan Frontier extra cab, and thinking going x2 15" ported x2 12" ported.. and thinking of going another x2 12" sealed or x2 10" sealed. I am looking for a wide range of hard hitting bass.
My question is this: assuming the box and ports and working great, would there be much of a difference with going x2 15", 12", 10", or say just 4x 15"?
a wide range of bass isnt about the subs its about the enclosure. u have to build the box to play that way. my 18s play from 10hz to 52hz with no problem and it sounds great. u should do 4 15s that would get down in that nissan
MrSkippyJ : My thoughts on different sized subs is for listening to a wide range of music.. techno stuff, death metal and some boomy drum n bass. I am concerned that if i just use x4 15's ported, that some of it will sound off or flat because the subs can not keep up.
UnderratedDB : are your 18's able to hit fast stuff like metal and techno? If they can and do it well.. I might rethink my build ( haven't bought anything.. just in research stage.
Thanks for the info guys.. its helpin!
By having a variety of different sized woofers, you run the risk of interference and cancellation.
When you have multiple woofers of the same size, in enclosures tuned the same. They will work as one, becoming more efficient. This not only can make SPL higher, but can give a more pure, easily controlled low end response. Basically, cleaner bass.
Bass frequencies are generally played 80hz - 20hz. And sometimes 60hz - 20hz. There is no reason that a properly designed enclosure could not achieve this with one sized woofer and would actually be more difficult to accomplish with various sized woofers.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
No reason a quality musical sub of any normal size in a well built and designed enclosure will have a problem with any music.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 6077 Guests (See full list)
