Soccerballzs Posted October 15, 2013 Report Posted October 15, 2013 Do you have a automatic antenna check if you do. They can go out and run battery down. Seen this happen to earlier models GM. (90's). this im not sure Check and see if it comes out of the body automatically or is it in windshield? http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
FuriousG Posted October 15, 2013 Report Posted October 15, 2013 You don't have an auto antenna, and don't just disconnect battery and stick meter in there. If it's a computer staying awake, when you dc battery it may reset and you will see no draw. You need to jumper the connection from batt to cable, disconnect cable, connect meter inline and then remove jumper. If you are looking for things to check, I have replaced dozens of BCM's in W cars for this, they like to stay awake.
finkster Posted October 15, 2013 Report Posted October 15, 2013 Why are we checking random things when we could just pull fuses and find out where the draw is coming from in the first place? It takes 10 minutes. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
finkster Posted October 15, 2013 Report Posted October 15, 2013 To add, by actually doing a draw test it helps to solve future problems using the same method. Just randomly checking things doesn't help you learn how to properly diagnose. It could be something as simple as a trunk light staying on to the power window stuck in the up position, all of which can be found in the same amount of time by just doing it the right way. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
99GPGTX Posted October 15, 2013 Author Report Posted October 15, 2013 Awesome vid. I will be doing this. Currently: 2015 Evo X WW Forgestar F14 18s --Rally Armour Mudflaps ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers Build: Crescendo Mezzos x2 Crescendo 800.4, 1500.1 Loaded Fi Q12 Second Skin Pro XS D5100 RF 360.2 Sky High Audio Wiring Need: ALTERNATOR! PREVIOUS 1999 Grand Prix GTX 3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded 12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids: Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit: knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400 TEAM DEADLY HERTZ!! Financial Consultant- Charles Schwab
99GPGTX Posted October 15, 2013 Author Report Posted October 15, 2013 Do you have a automatic antenna check if you do. They can go out and run battery down. Seen this happen to earlier models GM. (90's). this im not sure Check and see if it comes out of the body automatically or is it in windshield? Its in the windsheild Currently: 2015 Evo X WW Forgestar F14 18s --Rally Armour Mudflaps ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers Build: Crescendo Mezzos x2 Crescendo 800.4, 1500.1 Loaded Fi Q12 Second Skin Pro XS D5100 RF 360.2 Sky High Audio Wiring Need: ALTERNATOR! PREVIOUS 1999 Grand Prix GTX 3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded 12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids: Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit: knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400 TEAM DEADLY HERTZ!! Financial Consultant- Charles Schwab
99GPGTX Posted October 15, 2013 Author Report Posted October 15, 2013 You don't have an auto antenna, and don't just disconnect battery and stick meter in there. If it's a computer staying awake, when you dc battery it may reset and you will see no draw. You need to jumper the connection from batt to cable, disconnect cable, connect meter inline and then remove jumper. If you are looking for things to check, I have replaced dozens of BCM's in W cars for this, they like to stay awake. noted Currently: 2015 Evo X WW Forgestar F14 18s --Rally Armour Mudflaps ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers Build: Crescendo Mezzos x2 Crescendo 800.4, 1500.1 Loaded Fi Q12 Second Skin Pro XS D5100 RF 360.2 Sky High Audio Wiring Need: ALTERNATOR! PREVIOUS 1999 Grand Prix GTX 3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded 12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids: Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit: knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400 TEAM DEADLY HERTZ!! Financial Consultant- Charles Schwab
finkster Posted October 15, 2013 Report Posted October 15, 2013 My bet is on (and again, just follow the video and find out in 10 minutes) moisture/water in a light socket. Let's say in the unlikely event that 3 separate circuits have parasitic draw on them....you can STILL find all of them in under 10 minutes lol. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
99GPGTX Posted October 15, 2013 Author Report Posted October 15, 2013 Now i just need a jump to get the stupid thing charged up...two cars are on either side of me so i cant get a jump until one of them moves... Currently: 2015 Evo X WW Forgestar F14 18s --Rally Armour Mudflaps ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers Build: Crescendo Mezzos x2 Crescendo 800.4, 1500.1 Loaded Fi Q12 Second Skin Pro XS D5100 RF 360.2 Sky High Audio Wiring Need: ALTERNATOR! PREVIOUS 1999 Grand Prix GTX 3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded 12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids: Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit: knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400 TEAM DEADLY HERTZ!! Financial Consultant- Charles Schwab
jarrius Posted October 15, 2013 Report Posted October 15, 2013 Sounds like your alt is dead. When you test voltage from your alt make sure it's nice and warm first. My wife's alt went bad and the only way to find out was to let it run for a bit to heat up then the alt would not charge at all. The voltage went done to 11-10 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
