[email protected] Posted October 16, 2013 Report Posted October 16, 2013 So i just got my at 1200.1 today. And i also just bought a fiat 500. the alternator is only 95 amps. I'm pretty sure that amps not going to work on the stock alt (correct me if i'm wrong). but if i wired my sub down to say... 4 or 2 ohms (instead of 1ohm) is the alternator doing less work?
wccfan12 Posted October 16, 2013 Report Posted October 16, 2013 Yes, if you wire at higher ohm loads it will be less stress on the alternator, but honestly if that amp is 1200 watts at 1 ohm would you probably be fine with big three, an xs power batt or other AGM under the hood and 0 gauge to the amp. THE ANTHRACITE DYC CRUISER -Fully dipped anthracite grey pt cruiser -4 skar vvx 12's (version 1) -Mechman 240 amp alt -Big three in Cadence 1/0 -1 deka intimidator g31 blacktop under the hood -1 C&D 140ah Batt & 1 C&D 55ah batt in the rear -Re audio/soundstream mids and highs -Hifonics Zues 600.4 -DC Audio 3.5k
[email protected] Posted October 16, 2013 Author Report Posted October 16, 2013 ok. i might have to do that. this amp is the same as the ct sounds 1400.1 that steve meade tested last week (minus the bass knob). it did 2200 watts or something at 14.4 volts so im kinda worried about using a lot of amps
mikeg321 Posted October 16, 2013 Report Posted October 16, 2013 If your really worried just wire it to a higher ohm load while you upgrade your electrical then when you feel it's sufficient drop it down to 1 ohm and let it wang. 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
HHR Ed Posted October 17, 2013 Report Posted October 17, 2013 Stock alts are usually good to charge about 80-100 ah batts which can power up to 1500W amps. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
[email protected] Posted October 17, 2013 Author Report Posted October 17, 2013 okay. that makes me a little more comfortable. thanks guys
