audiofanaticz Posted November 18, 2006 Report Posted November 18, 2006 Well I get this funky smell in my trunk, Im 99.9% that my amp is frying my subs, Im running my gain on my line driver all the way down, and my amp gain almost all the way down also. When I have my gains set correctly, my stereo bangs for a few seconds and then my amp kicks into protect. The sub cones felt warm, and Im thinking my coils are just getting way too hott, and thats where Im getting my smell from. Ive sticked my noise in the port and wow, it smells bad So my question is, If my coils are starting to blow, will the sub ohms raise or lower? I know when I redid everything I put the subs on the volt meter and they where reading 1.16 if I remember right. The subs are dual 4 ohm, wired in parallel making it 1 ohm at the amp.
David Posted November 18, 2006 Report Posted November 18, 2006 from my experience they go up when they get brutaly hot
dmanson Posted November 19, 2006 Report Posted November 19, 2006 cut the gain on your linedriver down some 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
audiofanaticz Posted November 19, 2006 Author Report Posted November 19, 2006 gain on my line driver so so low already its not even funny, at the time when this happened it wasnt even showing 5 volts, and my hu is 4 volts..
