Soccerballzs Posted October 18, 2013 Report Posted October 18, 2013 Check and see if there are any DuPont suppliers in town they should have. If you route it to a radius use carbide bits. You can bring the gloss back by heating the edge after you sand it. Use a torch and move up and down the piece. If you see bubbles form you got to hot. Practice on scrap first. You can turn it on a lathe also. Used to build custom displays for stores and that's how I did the edges saves time sanding and buffy it. They have it in all colors also. You will need special chemical to hold the sheets together. Made a black and yellow gavel for a Judge in my hometown. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Wicks Posted October 18, 2013 Report Posted October 18, 2013 Check and see if there are any DuPont suppliers in town they should have. If you route it to a radius use carbide bits. You can bring the gloss back by heating the edge after you sand it. Use a torch and move up and down the piece. If you see bubbles form you got to hot. Practice on scrap first. You can turn it on a lathe also. Used to build custom displays for stores and that's how I did the edges saves time sanding and buffy it. They have it in all colors also. You will need special chemical to hold the sheets together. Made a black and yellow gavel for a Judge in my hometown. Great suggestions! Turning plexi on a lathe huh.............. That reminds me of something. Slightly off topic, but thats OK Check out this crazy SOB, I LOVE his videos: The stuff he does in his garage is mind-blowing. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Soccerballzs Posted October 18, 2013 Report Posted October 18, 2013 Check and see if there are any DuPont suppliers in town they should have. If you route it to a radius use carbide bits. You can bring the gloss back by heating the edge after you sand it. Use a torch and move up and down the piece. If you see bubbles form you got to hot. Practice on scrap first. You can turn it on a lathe also. Used to build custom displays for stores and that's how I did the edges saves time sanding and buffy it. They have it in all colors also. You will need special chemical to hold the sheets together. Made a black and yellow gavel for a Judge in my hometown. Great suggestions! Turning plexi on a lathe huh.............. That reminds me of something. Slightly off topic, but thats OK Check out this crazy SOB, I LOVE his videos: The stuff he does in his garage is mind-blowing. make sure you ease the edges before turning.(45') turn slow medium speed with very sharp tools also. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
K_SubieXT Posted October 23, 2013 Author Report Posted October 23, 2013 Check and see if there are any DuPont suppliers in town they should have. If you route it to a radius use carbide bits. You can bring the gloss back by heating the edge after you sand it. Use a torch and move up and down the piece. If you see bubbles form you got to hot. Practice on scrap first. You can turn it on a lathe also. Used to build custom displays for stores and that's how I did the edges saves time sanding and buffy it. They have it in all colors also. You will need special chemical to hold the sheets together. Made a black and yellow gavel for a Judge in my hometown. I don't think I have anything like that around here. my only option is lowe's and going online that I know of. also what grit sand paper should use and will just a regular propane torch work? My 95 Jeep Cherokee Build: http://www.stevemeadedesigns.com/board/topic/157643-1995-jeep-cherokee-build-sub-is-in-and-playing/
Soccerballzs Posted October 23, 2013 Report Posted October 23, 2013 When you final sand use 220 or 280 grit propane torch works great. Do nut use map gas gets to hot. Pratice on scrap pieces. Remember to keep torch moving. If you see bubbles forming you went to slow!! Good luck on your build and have fun! You can also put in oven and bend it also. 275'. Pratice will make perfect. Made some furniture years ago with some plexi in it. It is in a museum in N.Y. somewhere. Some kind of furniture museum. Have full cabinet shop. Use a triple chip blade on table saw to cut also. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
K_SubieXT Posted October 23, 2013 Author Report Posted October 23, 2013 When you final sand use 220 or 280 grit propane torch works great. Do nut use map gas gets to hot. Pratice on scrap pieces. Remember to keep torch moving. If you see bubbles forming you went to slow!! Good luck on your build and have fun! You can also put in oven and bend it also. 275'. Pratice will make perfect. Made some furniture years ago with some plexi in it. It is in a museum in N.Y. somewhere. Some kind of furniture museum. Have full cabinet shop. Use a triple chip blade on table saw to cut also. Awesome pointers! Thanks a lot My 95 Jeep Cherokee Build: http://www.stevemeadedesigns.com/board/topic/157643-1995-jeep-cherokee-build-sub-is-in-and-playing/
K_SubieXT Posted October 23, 2013 Author Report Posted October 23, 2013 Check and see if there are any DuPont suppliers in town they should have. If you route it to a radius use carbide bits. You can bring the gloss back by heating the edge after you sand it. Use a torch and move up and down the piece. If you see bubbles form you got to hot. Practice on scrap first. You can turn it on a lathe also. Used to build custom displays for stores and that's how I did the edges saves time sanding and buffy it. They have it in all colors also. You will need special chemical to hold the sheets together. Made a black and yellow gavel for a Judge in my hometown. Great suggestions! Turning plexi on a lathe huh.............. That reminds me of something. Slightly off topic, but thats OK Check out this crazy SOB, I LOVE his videos: The stuff he does in his garage is mind-blowing. make sure you ease the edges before turning.(45') turn slow medium speed with very sharp tools also. Do you remember what the shipping rates were from estreetplastics? it doesn't say anywhere on the site My 95 Jeep Cherokee Build: http://www.stevemeadedesigns.com/board/topic/157643-1995-jeep-cherokee-build-sub-is-in-and-playing/
Wicks Posted October 23, 2013 Report Posted October 23, 2013 Do you remember what the shipping rates were from estreetplastics? it doesn't say anywhere on the site Here was my biggest order: 1 of : 12" x 24" - Clear Acrylic Plexiglass Sheet - 3/4'' Thick Cast 1 of : 18" x 36" - Plexiglass Acrylic Mirror Sheet - 1/8" Thick Shipping was $16.81. I don't recall the exact rates but the shipping has always been reasonable for the great selection. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
K_SubieXT Posted October 23, 2013 Author Report Posted October 23, 2013 Do you remember what the shipping rates were from estreetplastics? it doesn't say anywhere on the siteHere was my biggest order: 1 of : 12" x 24" - Clear Acrylic Plexiglass Sheet - 3/4'' Thick Cast 1 of : 18" x 36" - Plexiglass Acrylic Mirror Sheet - 1/8" Thick Shipping was $16.81. I don't recall the exact rates but the shipping has always been reasonable for the great selection. If that's shipping for both of those, that's not too bad at all. I thought the over all pricing would be much higher then the prices they have on the sight My 95 Jeep Cherokee Build: http://www.stevemeadedesigns.com/board/topic/157643-1995-jeep-cherokee-build-sub-is-in-and-playing/
big dee Posted October 23, 2013 Report Posted October 23, 2013 Try your local glass shop. I've got some 3/4 thick but is very expensive . I can't remember exactly but 4 by 8 sheet ran around 400 to 600 .
