nice start. I also like how you upgraded the head unit with a nicer stock one. good job
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Thank you ...
must say between work and drive I did a bit everywhere in the world because my home islands they are no big deal.
As its actually my project is progressing slowly but I took the time to do things for meillieur result.
I have a right to know what volume of box I must have for the Subwoofer
SUNDOWN AUDIO X-12 D2 SUB PRO 12 "DUAL 2-OHM 1250W RMS SUBWOOFER BASS
To see if I have enough room in the trunk ..
Good and well condansateur and FAIL ... I will opt for 2 batteries.
I do not what is good and connection.
Can you help me and also tell me if the alternator will charge the battery 2.?
Thank you ..
ok sir big 3 need to be done in the front and the main batts needs its own ground
you can ground the 2 batt by it self in the rear of the car and yes if you run down a positive from the main batt to the second batt you should be able to charger it but first you need to do the big 3
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
thank you Elflako17
the shema 1 and good if I can understand your answer.?
I have a bit of trouble because I do not see on shema other instalation.
I think also put fuse on each battery.
However I do not know what to talk about the Big 3.?
you can do this as well
2010 Mazda 3
*Rebuild Time*
