I need some electrical help.
call mechman to see what kind of voltage regulator they used because the stock ones only charge 14.2v but lucky you can change it with this.after you change it it will charge 14.8v.
http://store.alternatorparts.com/d446xhd-35136-delco-type-cs144-series-voltage-regulator.aspx
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Snow, I'm gonna do that first thing tomorrow. Also my alt gets hot. Why could that be ? And that could be a good idea too, with replacing regulator
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
Hot is normal. You shouldn't be able to touch it hot is normal.
So long as it's not making any funny smells or noises
your lucky just change out the voltage regulator and your done on my truck its pcm control I have to bypass it an put in extremal regulator that is adjustable from 12.5v-15v but its easy to do.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   0 Members, 0 Anonymous, 1337 Guests (See full list)
