Aidan Hansen Posted October 23, 2013 Report Posted October 23, 2013 Hi all I have a question on what the enclosure's dimensions would be for these two 18" SunFi(Fi & Sundown) woofers in a wall. Here's what I have so far planned: Max Dimensions are 54"Wx33"Dx40"H I'm planning on triple layering the front and back then double layering the top, bottom, and sides. Orientation will be subs on the sides and slot port in the middle vertically. Powered by two AQ3500.1D's one on each sub. Tuned in the range of 36-38hz. Subs are BTL UFO Motors, ZV3 soft parts, and NS spiders. D1 Coils What should I be looking at interior volume? Anything helpful to this would be much appreciated! ^Vehicle log to come soon for this.^
smashedz28 Posted October 23, 2013 Report Posted October 23, 2013 Let the guessing begin! Gonna be hard to get a useful answer for that.
Miguels Posted October 23, 2013 Report Posted October 23, 2013 they are more like Frankenstein subs my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Aidan Hansen Posted October 23, 2013 Author Report Posted October 23, 2013 Let the guessing begin! Gonna be hard to get a useful answer for that. Well if I need to include any more info I'll try. No promises though. ^Vehicle log to come soon for this.^
MACnonsence6 Posted October 23, 2013 Report Posted October 23, 2013 well if you have the money to afford all the parts it cost to build those i need ufo motors btw pics of die!!.. then you should be able to afford a dayton tester this will give you the tiel and small parameters so you can acuratly build an enclosure to those subs specs' http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-806 I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Aidan Hansen Posted October 23, 2013 Author Report Posted October 23, 2013 Here's some pics: ^Vehicle log to come soon for this.^
Aidan Hansen Posted October 23, 2013 Author Report Posted October 23, 2013 well if you have the money to afford all the parts it cost to build those i need ufo motors btw pics of die!!.. then you should be able to afford a dayton tester this will give you the tiel and small parameters so you can acuratly build an enclosure to those subs specs' http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-806 Do you know anyone or where this has been reviewed and tested to where it's accurate or works at all? ^Vehicle log to come soon for this.^
SMZ2 Posted October 23, 2013 Report Posted October 23, 2013 well if you have the money to afford all the parts it cost to build those i need ufo motors btw pics of die!!.. then you should be able to afford a dayton tester this will give you the tiel and small parameters so you can acuratly build an enclosure to those subs specs' http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-806 Do you know anyone or where this has been reviewed and tested to where it's accurate or works at all?I am planning to get one of these myself. I is supposed to tell you the subwoofer free air frequency and all its specs. It is also good for resonate frequency so you know what you are tuned to not just guess. It's talked about a lot in these recent 4th order threads. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
MACnonsence6 Posted October 23, 2013 Report Posted October 23, 2013 look at the reviews on the website. pretty sure theres something on caraudioclassifieds.org about how to make something similar. but atleast this way uk the specs of each drive and could build a box accordingly instead of guessing. plus once you have it you have it for other projects I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Aidan Hansen Posted October 24, 2013 Author Report Posted October 24, 2013 I will definitely check it out! ^Vehicle log to come soon for this.^
