MACnonsence6 Posted October 23, 2013 Report Posted October 23, 2013 k so can anyone verify if the ct sounds 125.4 and the 125.2 as well as the audio technix 1200 are the same width and height? ik the 125.4 and .2 are and the 1200 looks like it should be but there isnt specs on ebay so im asking here. also does anyone know the length of the 1200 I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Swordlordboy1234 Posted October 23, 2013 Report Posted October 23, 2013 ask them on Facebook? My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
MACnonsence6 Posted October 23, 2013 Author Report Posted October 23, 2013 i dont have a facebook they look like there the same size width and height wise as well as aesthetically similar just noticed that the ct sounds 1400s knob has a volt meter on it pretty bad ass may go with that instead 100 difference in price but atleast then everything would match. im trying to see if i have enough space in my trunk to line all those amps up one after another in something like this --- -- - first being the mono 2nd being the 4 chan 3rd being the 2 chan then build little beauty covers to go over the spaces in between and also to hide the wiring I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Rmichael91 Posted October 23, 2013 Report Posted October 23, 2013 CT Sounds 125.4 dimensions - 15-13/16" x 2-3/16" x 7-9/16" CT Sounnds 125.2 - 8-3/4" x 2-3/16" x 7-9/16" The Audio Technix 1200.1 is roughly the same size as the CT Sounds 1400.1, basically just being a rebadge since they changed company names. Dimensions of the 1400.1 - 16-5/8" x 2-3/16" x 7-9/16" Hope this all helps
jarrius Posted October 23, 2013 Report Posted October 23, 2013 Edit: miss read original post 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
MACnonsence6 Posted October 23, 2013 Author Report Posted October 23, 2013 yes that helps alot thank you I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
