vw passat Posted October 24, 2013 Report Posted October 24, 2013 hi guys I have a subwoofer (RMS/Peak) 1000 W / 2000 W and an amp RMS Power 1 Ohm 1 x 1480W how much cuft I need to make the box? is tunned to 34hz thanks guys
Neckbeard Posted October 24, 2013 Report Posted October 24, 2013 Didnt even tell us how big the woofer is :| Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
truthsayer Posted October 24, 2013 Report Posted October 24, 2013 your sub should come with box recommendations. If you dont have that. Let the guys here know the sub size, and what type of box you want to run. Then they can give you their recommendations. truthsayer
vw passat Posted October 24, 2013 Author Report Posted October 24, 2013 sorry guys it's a 15'' for daily
Guest Posted October 24, 2013 Report Posted October 24, 2013 preferably need model numbers of woofers and amp.
hazestorm23 Posted October 24, 2013 Report Posted October 24, 2013 Model number would help as kranny said as each sub even the same line just different size can have different reccomended size box
vw passat Posted October 25, 2013 Author Report Posted October 25, 2013 my amp is ice-1500 and my sub xtr-300d2s but the reccomended size box on the web I think they are not good tx for help guys
slowfkncar Posted October 25, 2013 Report Posted October 25, 2013 I'm confI sed *edit (confused) because you say its a 15" ,your model number is for a 12"? Anyways,i have looked up the t/s parems and played with them a bit. The recommend enclosure seems right on target, what makes you think they are no good? The 15" calls for 2.7 net @ 40hz which is fine because it doesn't have much motor strength & xmech.
vw passat Posted October 26, 2013 Author Report Posted October 26, 2013 sorry slowfkncar you'r right that was the 12'' this is the 15'' xtr-380d2s. so 2.7 net on 1500w amp is good? and I tune my box 40hz for daily? or I leave it 34hz? thanks
