vw passat Posted October 26, 2013 Author Report Posted October 26, 2013 and I have this subwoofer as well but they don't give you information about box specs spl-380d2 it's a 15'' and im going to run this subwoofer with ice-3500d? slowfkncar can u give me suggestion how much cubic feet I need to make the box? thanks guys
vw passat Posted October 26, 2013 Author Report Posted October 26, 2013 any more recommendation's please?
Tarball Posted October 26, 2013 Report Posted October 26, 2013 What dimensions do you have to work with. Meaning, where the box is going, what are the dimension (preferably in inches) that you are willing to dedicate to box. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
vw passat Posted October 26, 2013 Author Report Posted October 26, 2013 I need to know how much cubic feet I need for my daily sub. the first post there is the sub and amp.
vw passat Posted October 27, 2013 Author Report Posted October 27, 2013 any more help? I don't know why when I post something no one reply me back ):
truthsayer Posted October 27, 2013 Report Posted October 27, 2013 you were already helped. and he told you 2.7 cu ft @ 40hz.. Even though you may run more power, just use the same box specs, as long as your sub can handle that power. truthsayer
vw passat Posted October 27, 2013 Author Report Posted October 27, 2013 ok so I make it 2.7cu ft but I can make the freq at 34hz? thanks for helping me guys
CleanSierra Posted October 27, 2013 Report Posted October 27, 2013 Yes, you sure can make it 34 Hz. Have you read anything about designing your own boxes and trying to figure it out? With the questions you ask, you would really benefit from some good reading and research. I've done tons of research and I'm STILL learning. I think you'd enjoy the hobby more if you learned how to do this yourself Im not the one you want to try to troll. Just a fyi for you.
vw passat Posted October 27, 2013 Author Report Posted October 27, 2013 Xmax (lin/peak) 13/26 mm is 12.5sq in. is good port area per foot?this sub have this xmax. im asking cause I'm STILL learning. I need it for daily. thanks
