Jermoslin281 Posted October 28, 2013 Report Posted October 28, 2013 Sub is going into my 02 S-10 extended cab. Would like slot port and sub facing up. DC recommended 1.25ft. What Hz and net ft do you recommened and would be the best for the most output. Im wanting the most out of rap/bass music, not doing competions but want every day SPL's. Using RF Prime R750-1D amp at 1 ohm with birth sheet around 950 at 1 ohm. I have torres calc but not sure of box specs, size, port, length etc......to perform at its best. All ideas welcome!
john253a Posted October 28, 2013 Report Posted October 28, 2013 side ported accross the bottom with sub up, is what ive found work well
sprkn_ranger Posted October 28, 2013 Report Posted October 28, 2013 I was happy with mine tuned to about 34ish. And had a net of 1.25 and 19.5sq/in of port area...I think if I were to do it again I'd test a little more port area but was overall satisfied with the results. Edit- And yea in a truck, sub up with port firing driver side across the bottom seems to yield the best results for most people. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Jermoslin281 Posted October 29, 2013 Author Report Posted October 29, 2013 Joe X worked a box up that I am very excited to build this week for my S-10. E n c l o s u r e S p e c i f i c a t i o n s : F b = 3 3 H z V b = 1 . 6 5 f t ^ 3 E x t e r n a l H e i g h t = 1 4 i n E x t e r n a l W i d t h = 2 9 i n E x t e r n a l D e p t h = 1 4 i n P o r t W i d t h = 2 1 / 8 i n P o r t H e i g h t = 1 2 1 / 2 i n C u t S h e e t L i s t : * A l l D i m e n s i o n s i n I n c h e s . * W o o d T h i c k n e s s i s 3 / 4 f o r a l l P a r t s . E x t e r n a l E n c l o s u r e P a r t s : T o p & B o t t o m = 2 9 x 1 4 L e f t & R i g h t S i d e s = S i d e 1 = 1 0 3 / 8 x 1 2 1 / 2 S i d e 2 = 1 2 1 / 2 x 1 2 1 / 2 F r o n t & B a c k = 2 9 x 1 2 1 / 2 L P o r t I n t e r n a l A s s e m b l y P a r t s : S i d e t o S i d e = 2 5 3 / 8 x 1 2 1 / 2 E x t e n s i o n = 4 5 / 1 6 x 1 2 1 / 2 A s s e m b l y g u i d e ( g e n e r i c d i m e n s i o n s ) :
sprkn_ranger Posted October 29, 2013 Report Posted October 29, 2013 Looks good man...let us know how it works. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Jermoslin281 Posted November 8, 2013 Author Report Posted November 8, 2013 the box at the one end is for an extra battery.... more to come if wanted. Do I need to start a build post in the member builds?
