RAVENSCROFT24 Posted October 31, 2013 Report Posted October 31, 2013 What does "Impedance" mean? My setup is going to be 2 hdc12's powered by a SQ2200d.1. Like it has the option for getting either a reagular impedance, D1 or a D2 subwoofer
Wicks Posted October 31, 2013 Report Posted October 31, 2013 1 or 2ohm voice coils. http://www.the12volt.com/caraudio/woofer_configurations.asp http://en.wikipedia.org/wiki/Electrical_impedance This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
RAVENSCROFT24 Posted October 31, 2013 Author Report Posted October 31, 2013 what would I need to get for those two woofers and that amp?
robby512 Posted October 31, 2013 Report Posted October 31, 2013 Impedance is your resistance or ohm load. When wiring the 2 12's the daul 1 voice coils will get you a finall ohm load of 1 ohm so your amp will reach its full potential of 2200 watts. If you run daul 2 ohms subs you could wire down to either .5 ohm or 2 ohm which at 2 ohm lets just say not sure on the exact specs of that amp you will reach something like 1600 watts.lower the ohm load the more power dropping below 1 ohm could damage the amp and so on. If you google 12volt wiring it will come up with a wiring diagram that lets you select how many speakers and what coils. You'd probably want to go with d1 coils so you can get that 1 ohm load and reach full potental Your subs finall ohm load will tell your amp how much power and what ohm it will play at
revoracing247 Posted October 31, 2013 Report Posted October 31, 2013 get dual 1ohm coils. wire the subs coils in series. (each sub will be 2ohms) and then wire the subs in parallel (load at the amp will be 1ohm) ~ If it was easy, everybody would be doing it ~
poorfish88 Posted October 31, 2013 Report Posted October 31, 2013 Impedance is your resistance or ohm load. When wiring the 2 12's the daul 1 voice coils will get you a finall ohm load of 1 ohm so your amp will reach its full potential of 2200 watts. If you run daul 2 ohms subs you could wire down to either .5 ohm or 2 ohm which at 2 ohm lets just say not sure on the exact specs of that amp you will reach something like 1600 watts.lower the ohm load the more power dropping below 1 ohm could damage the amp and so on. If you google 12volt wiring it will come up with a wiring diagram that lets you select how many speakers and what coils. You'd probably want to go with d1 coils so you can get that 1 ohm load and reach full potental Your subs finall ohm load will tell your amp how much power and what ohm it will play at No way a newbie should be running that amp .5 ohm. Plus you will need a battery or so in the back.
RAVENSCROFT24 Posted October 31, 2013 Author Report Posted October 31, 2013 thanks guys I really appreciate it, I plan on getting new wiring kit from knuknoceptz.com.........doing 4 gauge wiring
robby512 Posted October 31, 2013 Report Posted October 31, 2013 Oh I thought the damage part would make that point clear but running at .5 ohms is the worst idea ever just to get a few hundred more watts makes no sense
revoracing247 Posted October 31, 2013 Report Posted October 31, 2013 thanks guys I really appreciate it, I plan on getting new wiring kit from knuknoceptz.com.........doing 4 gauge wiring NO, run 0ga for 2200w ~ If it was easy, everybody would be doing it ~
poorfish88 Posted October 31, 2013 Report Posted October 31, 2013 thanks guys I really appreciate it, I plan on getting new wiring kit from knuknoceptz.com.........doing 4 gauge wiring You need at least 0/1 wire that amp takes and makes lots of power. 4 gauge won't cut it, like I said plus you need a AGM battery in the back by the amp, and I'd get an AGM battery up front. Got Ninja
