Hello, im getting my car install done this week, and I told them I need a 300 amp fuse. Is that big enuff for 6000 rms?
i'm gonna use a Distribution Block so i'll only be using 1 fuse, for both amps.
Fear The Quack!
Shot at 2007-08-19
fuses are for protecting the wire, regardless of the how big the amp is....i think there is a sticky in the electrical section about how big a fuse can be for a certain gauge wire...
i likes me some audio stuff...
i could be wrong but im thinking you would need at least a 475 amp fuse for 6000 rms i have never been over 2000 watts
6000 divied by 12.6 =476
geez, how big is that, and how much does it cost?
i'm only running 1 amp for now, so 300 fuse should be good.
plus i'm not even gonna run it at 3000 it'll be 1000 until i get new subs.
Fear The Quack!
Shot at 2007-08-19
again...fuses are for protecting the wire...here are the max fuse sizes for a given gauge of wire
http://www.stevemeadedesigns.com/board/ind...?showtopic=1005
Maximum Fuse Size
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
thanks thats helpful info
what amps?
DC.jpgDC POWER
Ok, well I told the shop I need a 300 watt Amp Fuse I guess i'm wrong on that.
I'm running 1/0 Wire 25 ft power, and 10 ft is ground.
2007 Chevy Cobalt.
No back up batteries yet but am gonna run 2 Kinetic HC 2400.
I know theirs a Amp Fuse Kit the fuses i was using before was 80.
I looked at the fuse Tutorial thing, and i'm lost.
2 MMATS DHC 1400.2 Modded with a Capacitor.
Edited by Twigz
Fear The Quack!
Shot at 2007-08-19
if ur using 1/0 wire than no bigger than a 325amp fuse...smaller is perfectly fine, but at least have a fuse that is equal to the amps fusing (if the amps are each fused with 125amps then smallest would be 250amp fuse)
