sbg Posted November 15, 2013 Author Report Posted November 15, 2013 I got this unit 2nd hand, was like that. Guy I got it from had it for 2 days then got a brand new jeep with nav. So he was going with the 360.3. And sold this one to me cheap, Said he just heard that u should do this to the unit so he did. I took it off and it didn't make a difference in sound, 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
cj92 Posted November 15, 2013 Report Posted November 15, 2013 hell of a start man looking good keep it up. New Build 92 Wagon http://www.stevemeadedesigns.com/board/topic/193327-back-with-a-new-build-1992-taurus-wagon/ Old 2005 Ford Mustang Build http://www.stevemeadedesigns.com/board/topic/174628-05-mustang-build-update/ Check out my Old build 98 Honda Accord http://www.stevemeadedesigns.com/board/topic/163280-1998-honda-accord-build/
sbg Posted November 15, 2013 Author Report Posted November 15, 2013 hell of a start man looking good keep it up. Thanks man, 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted November 15, 2013 Author Report Posted November 15, 2013 Picked up a USB cord today for my HU, so I can just plug my USB in up front or my cell. Going to try and fit it in my factory USB spot. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
MaxVolume Posted November 15, 2013 Report Posted November 15, 2013 A relay should be able to solve your video while moving problem (unless it's gps based). Use the remote out from your stereo to activate it (terminal 86). Connect a constant source of ground (ground a wire to chassis) to the common terminal (terminal 30). You can connect another wire in similar fashion to terminal 85, or just jump a short wire over from terminal 30. Either way make sure terminal 85 has a constant ground. Lastly connect your receivers e-brake wire to terminal 87. When your radio (or vehicle) is off, there will be no brake signal. A few moments after it turns on, the remote wire will send a signal to the relay, activating it and connecting terminals 30 and 87, making your receiver think you just applied the e-brake. And that's the end of my wall of text.
sbg Posted November 16, 2013 Author Report Posted November 16, 2013 A relay should be able to solve your video while moving problem (unless it's gps based). Use the remote out from your stereo to activate it (terminal 86). Connect a constant source of ground (ground a wire to chassis) to the common terminal (terminal 30). You can connect another wire in similar fashion to terminal 85, or just jump a short wire over from terminal 30. Either way make sure terminal 85 has a constant ground. Lastly connect your receivers e-brake wire to terminal 87. When your radio (or vehicle) is off, there will be no brake signal. A few moments after it turns on, the remote wire will send a signal to the relay, activating it and connecting terminals 30 and 87, making your receiver think you just applied the e-brake. And that's the end of my wall of text. I didn't have a problem HU never went in intell I had the stuff to hook it up right. relays don't work on. 2013 HU. I found this out so I took the relay I had got back and hooked a switch up when I installed. Never had a problem so far just flip the switch 1 time and done... 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted November 21, 2013 Author Report Posted November 21, 2013 Got a lot done. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted November 21, 2013 Author Report Posted November 21, 2013 Going to do some more clean up under the hood. Try and clean up the wire so they look factory. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted November 22, 2013 Author Report Posted November 22, 2013 Picked up a 12 in a prefab just to get by intell I can get some good subs and box 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted November 22, 2013 Author Report Posted November 22, 2013 I sound goodies came with the sub lol 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
