Elton Posted November 2, 2013 Author Report Posted November 2, 2013 It's a double cab only can run a sub under the seat that's like 5" mounting depth in running a sundown sae 1200
Soccerballzs Posted November 2, 2013 Report Posted November 2, 2013 What about i know everyone is going to go eww on this but 2 JL w1s they play pretty well in a sealed box and are cheap. 2 10s would rock in that box and only need a small amp Amazon has them for around $80.00 JL Audio 10W0v3-4 10" W0v3-Series 4-Ohm Car Subwoofer http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
nocturnalrites101 Posted November 2, 2013 Report Posted November 2, 2013 Thats a W Zero I was saying a W Onehttp://www.jlaudio.com/10w1v3-4-car-audio-w1v3-subwoofer-drivers-92081u can find them cheaper online
Elton Posted November 3, 2013 Author Report Posted November 3, 2013 I've got a guy local that builds boxes so no prefab crap
truthsayer Posted November 7, 2013 Report Posted November 7, 2013 Is the 5'' mounting depth with sub firing up. ( i think thats what your saying) If you fire them forward under your rear seats. You could get 2-10'' c2 audio subs for $200. And it seems people are comparing them to the sundown Sa series. 2 of the c2 audio's would match up good with your amp. truthsayer
nocturnalrites101 Posted November 7, 2013 Report Posted November 7, 2013 Those particular boxes are very good prefabs but which ever works
Elton Posted November 7, 2013 Author Report Posted November 7, 2013 http://www.foxacoustics.com/ProductDetails.asp?ProductCode=TDC%2D210%2DV%2D07
john253a Posted November 7, 2013 Report Posted November 7, 2013 in 1200rms with your budget, (most clamp at 1400) idd def got 2 subs as higher power subs will require more mounting depth and you should be able to get 2.5-3net under there so you could to 2x 8 or 2x10 it you air subs fwd idd go the e8 of save a bit more and go the sd2 (this is my choose)
Elton Posted November 7, 2013 Author Report Posted November 7, 2013 under the seat box to get custom made way to expensive hence just get a basic box and stick it on the seat I had a fi ssd 12 in a 2.5 cube box was way to big
