Jermoslin281 Posted November 4, 2013 Report Posted November 4, 2013 Building little system. Using a DC level 2 12 d2. Looking at two amps Rockford Fosgate Prime 750-1D or the Orion XTR 800.1. Any one have any ideas on a sub amp that's 1ohm stable and won't overpower this sub. Built custom box with 1.66 cu ft tuned at 33 hz.
trent420 Posted November 5, 2013 Report Posted November 5, 2013 I can tell u to stay away from Rockford prime series. They don't do rated power. I'm not sure about the newer Orion amps. Their old amps were beasts though. Find a sundown, skar, mmats or anything else along those lines and you'll be OK.
Miguels Posted November 5, 2013 Report Posted November 5, 2013 get a DC 2k. they have a sell going my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
biscuitownz Posted November 5, 2013 Report Posted November 5, 2013 I can tell u to stay away from Rockford prime series. They don't do rated power. I'm not sure about the newer Orion amps. Their old amps were beasts though. Find a sundown, skar, mmats or anything else along those lines and you'll be OK. Lol what are you talking about...Meade tested a prime amp and it did more than rated.
nocturnalrites101 Posted November 5, 2013 Report Posted November 5, 2013 Maybe a dc 1.2k lol that 2k is way over kill for a 600wrms sub. To bad its not a dual 4, it would have worked perfect power rating and let you add another one later on if you wanted
Miguels Posted November 5, 2013 Report Posted November 5, 2013 dual 2 ohms can be wired for final load of 2 ohms.. then you can get the 3rd one and wire at 1.34 ohms. the 2k gives you room to upgrade later.. thats what most of us do anyways i would get a 5k and run it at 8 ohms then keep adding subs.. everyone gets used to what they have and want more. even if you have a 155 db car you want to upgrade because its just not enough my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
dfoland93 Posted November 5, 2013 Report Posted November 5, 2013 dual 2 ohms can be wired for final load of 2 ohms.. then you can get the 3rd one and wire at 1.34 ohms. the 2k gives you room to upgrade later.. thats what most of us do anyways i would get a 5k and run it at 8 ohms then keep adding subs.. everyone gets used to what they have and want more. even if you have a 155 db car you want to upgrade because its just not enough THIS!!!!!! The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine
nocturnalrites101 Posted November 5, 2013 Report Posted November 5, 2013 dual 2 ohms can be wired for final load of 2 ohms.. then you can get the 3rd one and wire at 1.34 ohms. the 2k gives you room to upgrade later.. thats what most of us do anyways i would get a 5k and run it at 8 ohms then keep adding subs.. everyone gets used to what they have and want more. even if you have a 155 db car you want to upgrade because its just not enough He has one sub
81000D Posted November 5, 2013 Report Posted November 5, 2013 Prime did well over rated. Do your research before you go telling people what to and not to use on here.
Trey_Dog650 Posted November 5, 2013 Report Posted November 5, 2013 I'd still get the 2k 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
