Sky's 99 F150 build -Sundown X18-XS Power-Sky High Car Audio
looking good man, really clean truck i like the body style, are you planning on any off road lights or a grill guard?
Thanks bud. I think I'm done for the most part with the exterior of my truck. I don't wanna put any more money into it. I'm probably gonna be parting ways with it in about a year.
Did a little light painting today in the port. Ran out of paint.
Put the rest of the port together.
Sanded the corners on port piece.
The truck looks really nice. Wanna see more pics of the enclosure ;)
How are you liking your woofer amp? I recently just picked one up but haven't got around to putting it in just yet. Does it do alright with proper voltage?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
@standardcabspl thanks man.
@accordian. Should be cutting some circles tonight after I go buy a new router. The amp has done me solid for years. I had it to 2 15in T1s for a good year and half in a different vehicle on stock power and never had any voltage issues. My f150 now I think my battery is just toast. So I'm getting pretty bad voltage drop atm. I have my amp set with a dd1 so gains are good. My amp light is even dimming bad. I'm waiting on a few packages in the mail to fix the problem :)
New router jig
Test cuts
More paint to port
Double baffle turned out great
Old battery terminals. Super corroded!
Bolt cutters do great for cutting sky high wire. Below the bolt cutters is my old stock grounds. I couldn't believe the first one when I pulled it out..
Only way I could crimp this monster wire
Sky high 1/0 next to JL audio 0 gauge. Hard to tell but the sky high made my JL look like a baby. The JL is what I'm using for my amp.
Found some new wire at work.. MEGA gauge in 3ft spools :P
And a lil bit of port action
saw a torch and some solder. did you solder all the connections or just crimp them? and any pics of the wire installed?
I think you have a bit of truck stuck in your mud bro
~Ford Ranger, ext cab
Kenwood DDX470
1/0ga stinger wiring for big 3
1/0ga ofc flextech wiring
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
in a 27Hz tuned ported box
LE BUILD LOG!!!
  • Who's Online   0 Members, 0 Anonymous, 2006 Guests (See full list)
