(UBL) Project D.G.A.F - the SMDC Audio Tercel - 4 15" LVL 5 Walled - 18v, DC Audio 9.0k's EARLY SPL results pg 2 - Detachable Podium Page 3 4/30/15
  • Like (+1 Rep) 3
Follow my Tweet (Twitter)
This is a UBL (uninterrupted build log) - no comments (other then my own) and JUST pics! To leave a comment and join the discussion, click here:
http://www.stevemeadedesigns.com/board/topic/177546-project-x-the-smdc-audio-tercel-4-15-lvl-5-walled/
thanks! :) :)
First thing i had to do was find the old B-Pillar Plastic and re-install it. I plan on attaching the box to this to finish off my air-tight seal and make it look better as well. Before anyone asks, this thing passes the string test by 3/8" or more (with subs in place).
The plastic back in place
More fiberglass. The box has at least 2 layers, in some spots 3 of 19oz mat.
I used standard glass for most of the inside of the box due to not having good sunlight able to reach the depths of the "cave". For smaller area's, i used SunFlash so i could see how good my UV light works. It works GREAT! Only problem is, you have to move the light around. I could def initely use a bigger light or more of these. For kick panels or small area's, its awesome though!
This right here is the reason i like SMD Sunflash better then standard resin. I will be using this cup and brush for months. You can see how many i used just to do the inside with the normal stuff.
  • Like (+1 Rep) 2
Using an empty basket to predrill my holes.
These screws are the best! I been using them for years.
Drilling holes for the wires. There are 16 8ga wires that need to go to the trunk.
Time to put these beasts in. At about 80lbs each, i am in for a workout!
Now i did do some INTITIAL testing - only because i couldn't wait! This thing will have 2 DC Audio 9.0k subs @ 18v. Right now, due to having SO MANY 8ga wires to ghetto-twist together just to hear sound, i decided to try just 2 subs. I hooked them up to a CT Sounds 1400d that was on the bench. So give or take, 700 watts each, on 2 of 4 15's.
Yes, only 2 subs working. Watch the video to see how it did. I am not sure when i will have more progress but you know i will update you if i have some! thanks for watching!
  • Like (+1 Rep) 6
thanks! :):)
  • 1 month later...
Something got delivered today :)
now all i need is about 7 more D1600 Batteries and i can get started :)
D20468C1-F889-41E4-94BF-1B96E51DF267-318
34FDD854-A101-487F-A24B-F4B4F9DFB994-318
C219C6C5-5DAF-4BED-901F-E1A5149928C2-318
5213123B-4902-4E07-91EB-123194F37C1F-318
0509CF02-9F9D-4DDC-B860-08E8CDE31F6D-318
  • 2 months later...
1451614_10152126361800674_24706994500041
10007235_10152126361770674_4427917772662
thanks! :):)
  • 3 weeks later...
DC / XS POWER Lowering KIT FTW
how in the hell did you super-ninja me and post here? dammit i gotta fix the partner or super mod settings, you guys got too much access hahah
  • Who's Online   0 Members, 0 Anonymous, 2892 Guests (See full list)
