CleanSierra Posted November 16, 2013 Report Posted November 16, 2013 As far as length, to get the proper amount of port area, the port length will be long Im not the one you want to try to troll. Just a fyi for you.
JTeas Posted November 16, 2013 Report Posted November 16, 2013 How long should it be for 30hz with a slot port? And thank you
CleanSierra Posted November 16, 2013 Report Posted November 16, 2013 With that airspace and that tuning, like 50+ inches. Im not the one you want to try to troll. Just a fyi for you.
Joe X Posted November 16, 2013 Report Posted November 16, 2013 If we can believe Torres calculator it would need to be 68" in length 7net@30Hz with a 185 square inches of port area, the port itself would displace 8-9 cubes. How about that LOL.
shanesauce Posted November 16, 2013 Author Report Posted November 16, 2013 That is the thing that doesn't make sense, you get into subs that have a xmax of 30mm and your port area and lengths go through the freaking roof. How can you meet in the middle between the "rule of thumb" 12-16 port area per cube and the xmax calculation? I am starting to think 20 inches of port area per cube is a happy medium at least in terms of the higher xmax subs. - 2012 Mustang 3.7 Manual - Audio under construction
CleanSierra Posted November 16, 2013 Report Posted November 16, 2013 If we can believe Torres calculator it would need to be 68" in length 7net@30Hz with a 185 square inches of port area, the port itself would displace 8-9 cubes. How about that LOL. Haha, I knew it was going to displace a ton of volume. I never actually did a calculation, I was guessing in the 50s with crude math. That's insane though, if you want that amount of port. I have never realized that they had 40MM of Xmax. Im not the one you want to try to troll. Just a fyi for you.
JTeas Posted November 16, 2013 Report Posted November 16, 2013 So i should make it like 8^3ft internal before displacements?
JTeas Posted November 16, 2013 Report Posted November 16, 2013 The way i did it was a port 11(w)x16.75(h) and got 68 inches of port length... thats a lot...
