im still a noobie when it comes do doing stuff on my car and im afraid of breaking something because i just have a habit for accidently breaking things
what i want to do is replace my trunk light with some neon lights because its just not bright enough in there and i want to know how to do this with out fuckin sumthin up
here are some pics
whats positive and whats negative
ill have a video as well if this isnt makin sense
lmk thanks
Edited by .Supra.
just try touching the wires to positive/negative on battery. this light wont mess up. thats how i do it to test them when i used to put them in my atv... but if i remember silver wire should be positive..
current set-up:
headunit: kenwood excelon kdc-x891
mids: front: mb quart reference 6.5s rear: pioneer TSA941 6x9
mid and high amp: performance technique ICBM-773
sub amp: kicker 08zx2500.1
subs: (2) 08s15l7d2
4.25 cubic foot sealed box
big 3 all in hooker 1/0 wiring
Sacrifice your car to the Audio Gods and DBs will come.
x2 poke and prod , just dont touch the wires together to cause a short and youll be fine
Edited by mrwigglezdj
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
aight thanks guys
heres that video so if you hate reading
(theres a lot of people lookin at this thread lol...this forum is the best)
Edited by .Supra.
The packaging that that light came in should tell whats postive and negative i used to put those on mopeds for like 75 dollars a piece. The wire in your trunk the negative should the one with a stripe on it
Ive always thought that the copper wire was positive and the silver wire was negative. Just put the wires in that connector one on each side and see if it lights up if it doesn't switch them around. See if you can get like male terminals/connectors from autozone unless you have some and see if they will fit into the stock light connector tight and then crimp both pos and both negs to the male terminals and plug it into the connector and you'll power both.
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Im pretty sure those need a inverter box and cant be hooked straight to dc
DC.jpgDC POWER
Don't think so I bought one with a cigarette lighter end on it and I chopped it off and tapped into my brake lights with wire taps so when at night time only I would turn on my lights it would automatically turn on.
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
