Renault Megane 4 Fi sp4 18s Walled 12k -- 510 pics
Started making a front peice that goes below the floor
It finally fit good enough so just trimming it so it sits under floor
Need to cut out a channel so i can fit the cables down there
Having RCA on the left speaker cables in middle and power on the right
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 Renault 210a Alternator
1 Hertz 15k Spl Monster
2 RF T600-4
16 RF T162s 6.5" Mids
16 RF T1T 1.1" Tweeters
4 FI SP4 18" D2 subs
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Build Log: http://www.stevemeadedesigns.com/board/topic/178428-renault-megane-4-fi-sp4-18s-walled-12k-457-pics-termlab-scores/
Time to check on the foam see if its hard enough
On this back piece i also have to leave access to the bolts for my rear shocks for when they need changing
Should be enough space there to undo it when needed
Bit too tight to get the back panel all the way back
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Another sheet should do second layer on the floor and back panel
Using first one as a guide good job i didnt stick it already
Thats a big piece to try get in my car through the door on my own
It was a big struggle and a very tight fit bit its almost in
Bit of trimming to get it round the arch and should fit better
Just enough time to try get this back piece to fit before its too dark
Too dark to see now but it fits
None of this has been glued or screwed yet as im waiting on my speaker cables and rca to run them before they covered.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Ive been tempted to run 8 sets of speakers per door doing 4 sets off each T600-4 amp but i dont think ill be able to fit 16 runs of speaker cable through the door to the crossovers.
Would it work if i linked all the speakers in the doors with 8awg then all the tweeters with 8awg and run that and split into 14awg into each crossover?
The 2 amps put out different power so im not sure how it would affect it linking all speakers together.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
welcome to the forum bro. Looks like you know what your doing. And i'm sure this will be a nice finished product.
truthsayer
Thanks. This is my first big build so if anyone has any tips or advice it would help.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
