PSIFocus Posted May 7, 2014 Author Report Posted May 7, 2014 I wish I was willing to go wild but I like how the car does in the stock classes and its fun maybe one day ill go wild! What is your number goal?
alaskanzx5 Posted May 7, 2014 Report Posted May 7, 2014 Well I plan on 2 t1500.1bdcp at 2ohms. So roughly 3k rms 80amp draw per from what RF tech said when I called them. 6.5-7cuft tuned in the 32-34hz area. 2 t2d415. With a single t2d415 @ 2 ohms on a t1500.1bdcp box about 3.5cuft 35hz. Did a 142.? If I can gain 3db from I stalling my alt, getting a better batt bank, deadener, double cone and power I'll be happy. So a 145.? Would make me happy. If I get up to a 147ish I'll be impressed. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
PSIFocus Posted May 7, 2014 Author Report Posted May 7, 2014 That should sound nice once completed for sure!
alaskanzx5 Posted May 7, 2014 Report Posted May 7, 2014 Yeah I'm not chasing numbers, I realized quickly I would rather play music with authority then burp at 51hz. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Nightshade Posted May 8, 2014 Report Posted May 8, 2014 Well I plan on 2 t1500.1bdcp at 2ohms. So roughly 3k rms 80amp draw per from what RF tech said when I called them. 6.5-7cuft tuned in the 32-34hz area. 2 t2d415. With a single t2d415 @ 2 ohms on a t1500.1bdcp box about 3.5cuft 35hz. Did a 142.? If I can gain 3db from I stalling my alt, getting a better batt bank, deadener, double cone and power I'll be happy. So a 145.? Would make me happy. If I get up to a 147ish I'll be impressed. I can design you a box that with very little work should do low 150s off the equipment you named. I'm talking on the dash too homie. Pm me and I will give you the specs. Oh yeah the tuning will be right at 36hz and should peak at 42hz on a burp depending on deadening. The same box I was able to play music at a 153 on the dash with all day long. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
PSIFocus Posted May 8, 2014 Author Report Posted May 8, 2014 The box is tuned @ 35hz the car just peaks at 51hz no matter what I/we have tried. This car does extremely well on the lows as well as meters well. I have limited myself by keeping all of the equipment in the storage are with zero modifications to the car other than 2 holes for cable. If I was willing to modify the car I know it would play louder and lower. This car was made to be a daily pounder not a meter chaser. It is pretty nasty. Nightshade would you mind sending me those box specs as well? Thanks
PSIFocus Posted May 20, 2014 Author Report Posted May 20, 2014 I am looking for someone that does Plexi work Thanks!!
PSIFocus Posted December 15, 2014 Author Report Posted December 15, 2014 Made some changes to the setup. I think they turned out well. What do you guys think?
alaskanzx5 Posted December 15, 2014 Report Posted December 15, 2014 Looks good. How close does the glass get to the magnets when you close the door? Always thought about invert mounting in mine. Just didn't think it would work with such a big box. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
azscott Posted December 15, 2014 Report Posted December 15, 2014 I really like the way everything looks, it is really clean man props to you.
