kadrek Posted November 13, 2013 Report Posted November 13, 2013 I've never seen a mono amp with four places to put speaker wires. Which of the four places would I put the wires from the subwoofers in? The two to the right like in the manual? Would that give 500 rms @ a 2 ohm load? Amp in question: http://www.amazon.com/Pioneer-GM-D8601-Class-Amplifier-Remote/dp/B00A02QLVA Or would this amp be better? http://www.amazon.com/Alpine-MRV-M500-Mono-subwoofer-amplifier/dp/B00BMR7UPS Thanks in advance!
rockFord_Expedition Posted November 13, 2013 Report Posted November 13, 2013 I answered this where you asked it in your other thread. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
rockFord_Expedition Posted November 13, 2013 Report Posted November 13, 2013 When a mono amp has more than one speaker terminal it doesn't matter which one. Think of it as a distribution block. Just pick a set and your done. No need to try to "bridge" anything. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
kadrek Posted November 13, 2013 Author Report Posted November 13, 2013 When a mono amp has more than one speaker terminal it doesn't matter which one. Think of it as a distribution block. Just pick a set and your done. No need to try to "bridge" anything. Okay, thanks. Sorry, I was in a hurry.
twisted1 Posted November 15, 2013 Report Posted November 15, 2013 Its just there for convenient wiring. . If amp said 500.2 then you can bridge it. 09 mustang gt
bassman619 Posted November 20, 2013 Report Posted November 20, 2013 If u use both sets of inputs on a mono amp what it will do is act like you have the two sub woofers wired in parallel.. so say you wire one 4ohm dual voice coil sub to each channel with the coils on the subs wired in parallel it will result in a one ohm load ..idk what they even put two channels on it when its really one channel You need trunk space to get groceries and shit...bitches love groceries
rockFord_Expedition Posted November 21, 2013 Report Posted November 21, 2013 If u use both sets of inputs on a mono amp what it will do is act like you have the two sub woofers wired in parallel.. so say you wire one 4ohm dual voice coil sub to each channel with the coils on the subs wired in parallel it will result in a one ohm load ..idk what they even put two channels on it when its really one channel A little late to the party bud. They put two sets of speaker outputs to add wiring flexibility and allow larger wire runs without trying to squeeze two larger wires into a smaller connector. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
gattiboy13 Posted November 22, 2013 Report Posted November 22, 2013 FYI...Awesome amp, it pushes some real power very clean and never heats up at 1ohm.
